So I had p0141 and p0036
I previously had lean codes also since the wires were destroyed and left it dangling for a year. When I got a guy to do my rear main seal he pulled trans and spliced the wires back together with some blue speaker wire it looked like for extensions.. I pulled it today and put a new sensor but had to hardwire it again. I soldered wires on and I'm thinking maybe he had them crossed originally as I just put them back how he had them with better splicing. I checked for impedance and than voltage and that's how I decided it was indeed heater. Heater wires did have voltage with key turned which I was thinking was normal. Basically was laying around on my back almost all day and didn't solve anything so I'm definitely irritated. Basically trying to figure out the heater to see if I can get rid of the codes since it's possibly making the envoy run crappier than it could. Also need to fix knock sensor harness from when my buddy and I did the oil pan baffle a year ago 😩 thanks for any help.. tired and need to eat... raining so probably won't mess with it again today but if I do it'll be adding male/female disconnects or checking fuse type stuff. Unsure if the wires were in the right position to begin with but I figured if it was wrong it would've tripped a fuse...
