O2 Sensor: bank 1 sensor 1 access
CajunWon
137
Cary, NC
Yeah, I'm on an O2 binge: Today attempted to change the (edit) LEFT front sensor, this one not coding any errors -it's just old. Breaking it loose more difficult than bank 2 sensor 1, but the connector appears impossible to access. Looks like the drive-shaft has to come down, but even then not sure can get both hands on it to pull the lock pin and disconnect/reconnect from below. From the top would have to disconnect a few vacuum tubes and a fuel line, but I can't even see the connector from top.
I gave it a cleaner squirt and gave-up.
Any pointers?
Right side is a biatch. Go by the right wheel well to access the connector. Then remove it from the pipe.
To install, I just learned a trick for my Caprice which seems to be similar for placement. Before installing it, connect it and snake it into position. Then pre-twist the wire a few turns and install it.
Left side is a bit easier. Again, access from the wheel well but the wire isn't as short.
CajunWon
137
Cary, NC
Sorry, can't tell right from left, corrected above.
It's the Left sensor, bank 1 sensor 1 I'm having issue.
CajunWon
137
Cary, NC
Fixed!
Remove bolts from front driveshaft to push aside for access with both hands.
150 miles yesterday. Seems to make almost 2mpg improvement with 2 new upstream sensors.
MEHMET ONUR
