04 rainier was 9 degrees out started truck was rough and sounded weird battery gauge went out of wack past 19 is now stuck burried to the right. Let it warm up some
Drove for a good 10 miles and heat was blowing cold. Shut off did some errands got back in punched it hard then heat started working
This morning again 9 degrees start truck now its rough kind of bouncing truck side to side slightly then smoothed out then again no heat
Drove good 20 miles. No heat. The coolant guage is straight up down
Checked rear heat nothing. No idea if ac works as its 9 degrees out
Any help be apreciated
