SOLVED! No crank, sometimes clicks and other times doesn't
Hobbyist4Life
94
Qatar
Hi, it's me again! :bonk:
My '06 Envoy XL Denali 5.3L LH6 has stopped cranking out of the blue. It's been sitting in the scrapyard since late 2011, so I can't get shocked if the starter suddenly went bad.
When I attempt to start the vehicle, the starter sometimes clicks and doesn't turn over, while other times I can't even hear it click. There are also times where it just fires right up.
If it clicks, it will eventually work after an unknown number of attempts (every time is different). If it doesn't click however, I have no idea what to do!
Here's what I've done:
- Confirmed the relay is working properly.
- Sanded down the main connections from battery to fuse box (were a bit rusted and not providing electricity when I first bought the vehicle)
- Attempted removing the starter or at least check the wires back there (I was stranded in the street at the time) I unbolted the starter but couldn't either remove it or find the space to disconnect the wires, so I just banged it around and reinstalled it and wiggled the wires back and forth thinking it would start the vehicle if it was a no/loose connection.
After all that, I do believe that the starter needs replacing. I'm not sure what exactly went wrong with it, internally or externally. But I do, however, know that I need to get this fixed and have peace of mind that it will at least crank every single time!
Oh, and no, the battery is not the problem as I have purchased a new one after this problem started.
Awaiting suggestions on what to do next.
I do have another starter (from scrapyard) but I need to check it for functionality first.
7,692
Given the Denali's "Salvage Yard Hiatus" of Eight Years...and in consideration that long periods of dormancy can invite Rust and Corrosion under such conditions... This Link would be a good place to "Start":
Check all of the Grounds relevant to the Starter Circuit by unbolting or unscrewing each one and after using a piece of Crocus Cloth to remove anything in between down to Bare Metal, apply a Dollop of Dielectric Grease to the surfaces and reattach the Eyelet(s) after Wire Brushing off any Green Corrosion or residue. This action alone could revive the Circuit well enough to Wake Up the Starter.
Then if the turn of the Ignition Key produces the same result... Review the Starter Circuit Diagram for any problems with the Circuit Breaker-Fuse issues for continuity ...and Test the Starter Circuit using the Relay Bypass Technique shown in @MAY03LT 's Video as this may disclose that there are NO possible problems being within the Starter Solenoid or from any excessive Electrical Resistance in the Stater Motor itself.
Eric "O" from South Main Auto covers (actually...uncovers) another No Crank No Start situation that focuses on the Starter Ignition Switch which may also be involved with additional Testing and Probing required:
Besides having a decent Digital Multi-Meter and a Pin Probe "Scope On A Rope" available in your Working Tool Kit... You'll be wise not to condemn the Starter outright without having looked these other areas over first.
You can also find all of the Diagrams you will need for such things by Downloading a Complete GM OEM Service Manual (Courtesy @Mooseman) at THIS Link for Best References for your Year/Make/Model SUV:
If it comes down to cases and you must replace the Starter... you will need to take additional actions described in this Video in order to get the Old Starter OUT and the New Starter IN:
Hobbyist4Life
94
Qatar
@MRRSM Thanks for your suggestions, I'll be tackling some of them when I have the time.
As for now, it seems like I've skipped mentioning some of the troubleshooting that I've done.
I have already tried bypassing the starter relay like MAY03LT did in the video. It still does the same thing. I can also see sparks when inserting/removing the wire inside the pin-hole.
I've also tried replacing the ignition switch with the one from my TB, same thing.
I haven't checked the grounds, and I couldn't find a way to disconnect the wires from the starter. It's a tight space with the axles and everything in the way.
What's confusing me is that sometimes it cranks from the first time without any issues. Sometimes for a couple of times, and sometimes the whole day like what happened yesterday.
I've recently started working in a company so I don't have as much free time as before.
I also suspect the starter is the problem because it seems like sometimes the starter's gears don't retract all the way, and an annoying noise comes from the flywheel/starter/torque converter area. If I shut the engine off and start it again (once, or maybe a couple of times) the noise goes away.
I do have a video of this noise on my phone, it's like something is grinding.
Edit:
Also sometimes this noise comes for the first couple of seconds and goes away. If it doesn't come directly after starting, it won't come.
I'm trying to upload 2videos but it says this video doesn't allow extention 🤔
If it does the same thing while jumping the relay socket, the starter is likely dead. Unless the main ground from the battery to the block is bad, not likely that's the problem but worth the check.
Getting the starter out of the V8 version of these trucks is a bitch.
Reactions: Hobbyist4Life
Hobbyist4Life
94
Qatar
Yeah, I noticed from the videos.
Today it doesn't want to crank. Doesn't even click (clicked the first time without starting, and stopped clicking) I've checked the voltage between the +ve battery terminal and various points on the block, no issue there.
At this point, it's either the wire from the fuse box to the starter (I don't think so), or the starter itself.
I'll try to upload the videos from my laptop, see if it works
budwich
2,043
kanata
measure the resistance (to ground) from the relay contact going towards the starter. Do the same measurement at the starter where the relay point / wire comes in. That will tell you which is bad... the wiring or the starter.
7,692
One Last and Very Important Thing Worth Mentioning here is THIS:
If a SHIM is called for during the Installation of either the GM OEM ACDelco Starter OR from any After-Market Starter and you discover that it was MISSING... the displacement of the Starter inside the Flex-Plate "Well" where they are supposed to make Post-Bendix Spring Launch of the Small Motor Gear...it might be getting jammed up inside there as a result. A Symptom of this problem is the non-retraction of the Small Gear back inside of the Starter after the Ignition Key is relaxed into the RUN position from the Ignition START forward-most Position.
Hobbyist4Life
94
Qatar
The problem with what you're saying is the tight space around the starter. I haven't checked for space behind the wheel, but I know that from under the car and from under the hood is kinda difficult.
Especially because the multimeter doesn't have that long of leads. I've been thinking about buying a test leads kit to open more possibilities.
I once have tried to remove it while car didn't want to start (stranded in the streets), I haven't noticed any shims. Also, I have another starter that I'm willing to install but first I need to get it tested because it's from a parts car that I bought for this Denali.
The parts car (previously) had a problem with the transmission, so one of the garages bought it and took the engine as a replacement for a 5.3L TB. Since it was a replacement, most of the parts other than the engine and transmission they put inside it.
Now the problem is, if I really DO need a shim for THAT starter to be installed (I'm assuming it's the factory one), how will I put my hands on one? I'm pretty sure buying a random shim online is not the proper way
budwich
2,043
kanata
so... at least measure the resistance at the fuse panel.
Reactions: TJBaker57
Hobbyist4Life
94
Qatar
"measure the resistance (to ground) from the relay contact going towards the starter."
This is the only part that seems to be talking about the fuse panel. And it's confusing me. From relay contact to ground? Or to starter relay wire?
As far as I know the relay sends power, not ground, to the starter. So measuring the resistance from relay contact wire to starter ground (which is the engine) is not making much sense to me.
Can you please tell me what to measure exactly?!
budwich
2,043
kanata
Look... pull the relay out of the fuse box. You know which pins go where in the fuse box. All I am asking is now go on the relay box, put a red lead of the meter on the pin / connector where the contact for the relay that was going towards the starter and the black on a good ground and measure resistance. Not sure why this is so hard. :-(
Hobbyist4Life
94
Qatar
Because I don't get why 🙃
I'll check that anyway. What value should I expect?
I personally think it should show open circuit
budwich
2,043
kanata
Why? because, in most cases, your eyes can't see the state of an electric circuit. Your observations are not electrically based... just visual. Nothing may result but it certainly won't hurt.... and it may solve your "mystery".
TJBaker57
2,900
Colorado
If the power as you call it doesn't have a path to ground then absolutely nothing will happen when the relay supplies that power. If there is a path to ground then an ohm-meter hooked up across that will read that path, expressed in ohms resistance.
The starter motor needs a complete circuit to function. The ground is already connected at one end of the starter motors windings. By checking with an ohm meter at the fusebox starter relay contact that leads to the starter you are verifying that path to ground through the starter motor windings. If the circuit is open then either you are in the wrong terminal, there is a bad connections somewhere, or the starter is toast.
7,692
@TJBaker... "Instructions... Without Judgement = FTW!" :thumbsup:
Regarding the Use of Shims for the Starter Installation... Realizing of course that if this becomes necessary... the Shims ordinarily only require LOOSENING the Inner-most Bolt and then removing the Outer Bolt in order to slip them In and Out... without necessitating the COMPLETE Removal of the Starter for any multiple "Trial and Error" adjustments:
Dorman makes a Very Handy Assorted Style and Thickness Starter Motor Shim Set for Under $5.00 that will suit your purposes to gain the correct "Goldilocks" Mate Up Spacing between the Small Starter Gear and the Flex-Plate Fire Ring Gear:
Eric The Car Guy Explains "WHY" Shimming may become necessary... and How To Do This Job:
Hobbyist4Life
94
Qatar
@MRRSM, thanks for the info and the link. Are you sure those spacers work for our 5.3L engine?
@TJBaker57 I have measured the resistance from the relay pin to ground, it's settling around 2 ohms. Half of that seems to be introduced by the multimeter itself (shows ~1 ohm when connecting both leads to each other).
I have also bench measured the resistance of the other starter, and it gives almost the same results.
So... Any suggestions on what this means? Are both starters busted? Or both are working and the problem is elsewhere?
Ugh, this is getting annoyingly annoying :Banghead:
I just don't feel like spending the time to replace the starter while it's not the actual problem.
Oh, one last thing that I just remembered, which might change the whole situation. When I previously attempted to remove the starter, I noticed that the plastic cover wasn't there and I can see the flywheel and the insides.
What are the chances of a rock ot a similar matter getting thrown up in there and holding the starter?!
7,692
I cannot swear that the Dorman Flavor of the Shims will be a Perfect Fit... However... Given that the far end of the Tang is OPEN... it should allow a certain amount of Fudge Factor in aligning the Inner Distance to the Outer Bolt as it passes through the completed Shim Hole and into the Outer Mount Bolt location.
Since you have an Extra Starter on hand... you can always measure the distance between the Mount Bolt Holes Center to Center and look for any Off-Set to confirm you won't require the "Zig-Zag" version of these Shims. "Oh... Oh... Oh... O'Reilly's..." has a bewildering array of Starter and Other Body Shims to choose from if you peruse their offerings via this Link:
TJBaker57
2,900
Colorado
First off...when you say "click", where do you believe this click is coming from? Down by the starter? Under normal startup there are at least 2 items that click but these are normally drowned out by the starter motor. The louder click will be the starter solenoid which is part of the starter itself these days. (Its job is to connect the big power from the battery to the starter motor windings) A lesser click that will only be heard in a quiet environment (no radios or such) comes from the starter relay in the underhood fuse block. I am guessing here you mean the former, louder click from the area of the starter motor itself. If that clicks and the starter doesn't go then it is either the starter motor, the battery cable connections from the positive battery post to the large connector on the starter motor, or the grounding of the starter motor.
In the past I have had vehicles that got a "bad spot" in the starter motor. (Worn brushes or the like) when the vehicle clicked but did not turn the starter I have been known to smack the starter body with a large wrench or hammer and it then started 😆
TJBaker57
2,900
Colorado
A note and observation after watching May03lts video about bypassing the starter relay. When I watched him do the bypass it wasn't clear which two relay sockets he had his jumper in. I could see where someone who was unfamiliar with the relay configuration to bypass an incorrect relay socket terminal. @Hobbyist4Life ...was your jumper across the terminal diagonally??
Edit: I failed to point out I am seeing the video on a smartphone. It may well be clearer in fullscreen on a larger monitor
budwich
2,043
kanata
So... it would appear that you have a path for your starter (from the start relay) to engage the solenoid. As you have found, the resistance isn't an "open circuit" and compares with your "other starter".
As suggested, you need to determine that, indeed, the solenoid on the starter is "clicking" / activating. Jumping the pin that you just measured the resistance at to a battery should cause the solenoid in the starter to click / pull up. Does it?
Of course, you can test your "other starter" on a bench by doing the same test.... providing 12v to solenoid contact / pin and ground somewhere on the case. The solenoid should click / activate. If it doesn't then that starter has a solenoid issue... some can be replaced while some starters are not serviceable in terms of replacing the solenoid.
NOTE: there are other electrical tests there after that you can perform IF the solenoid on the starter does pull up.
Hobbyist4Life
94
Qatar
"nOh... nOh... nOh... O'Reilly's NOT an option" :smile:
I don't think I'll need shims, but I won't know for sure until I get it installed. I'm hoping to have a decision in the next couple of days if the starter really is the problem.
When I say "click" is when the solenoid tries to engage the teeth. I can only hear the starter relay when, as you said, in a quiet environment AND have the hood and fuse box open.
Yes. The problem is there comes a time where it starts right up as if nothing's wrong, and other times it clicks in a couple of attempts to start and then it starts. Other times (which is the current situation since 3 days) I can't even hear it click with the radio and everything off!
Actually the first time it didn't crank, I was at a shop that does several light repairs. I had a bad battery at the time and told him to install a new one and it still didn't crank. Then he started "smacking" the starter but nothing happened, still didn't want to crank!
The first time I watched it, it was pretty clear to me, also on my phone. I'm not sure why it wasn't clear for you, maybe your phone is too small :rolleyes:
As I mentioned above, the starter has a mind of it's own when it comes to that!
I'm planning to connect and test the "other starter" but I'm just not finding the time for it. Also, AFAIK there are no shops around here that have starter testing machines.
I might just pull the trigger and remove the old starter and start bench testing on that!
What are the other electrical tests you're talking about?
Hobbyist4Life
94
Qatar
Finally got around replacing that POS. I had split it into 2 nights simply because it was stuck between the chassis and transmission as can be seen in the video @MRRSM posted above.
I've tried to unbolt the passenger engine mount and jacked up the engine like in the video, but still didn't get enough space. I ended up also unbolting the transmission mount and lifting the transmission to finally get JUST ENOUGH space to get the POS out.
It seems like the bendix drive broke itself free from the lever. haven't opened it yet for inspection but I guess it's either a broken lever or just separated.
Also, surprisingly the solenoid's housing has a hole on the edge :blinkhuh:
I'll take some pictures of it later tonight when I get home
Reactions: mrrsm and Mooseman
Hobbyist4Life
94
Qatar
As these pictures should be enough to show my sufferings.
In case if it wasn't enough, here's a quick video that shows the situation of thw bendix gear
7,692
The other Additional Caution necessary is that prior to attempting to Jack Up the Engine after loosening the Passenger Side Motor Mount is to CHECK FOR THE AVAILABLE SPACING BETWEEN THE BACK OF THE INTAKE MANIFOLD AND THE METAL BODY AT THE FIREWALL. Doing so will let you know JUST how much room is available B4 anything on the IM makes contact and ...starts to "Crack".
Hobbyist4Life
94
Qatar
Well, thanks for that info. I'll keep it for (hopefully not) the next time I need to replace it.
Also, I didn't go crazy raising the engine, I did like in the video not allowing the mount's studs to go fully out of the chassis.
At least the darn nightmare is over :celebrate:
7,692
For the sake of Future Sufferers of this issue... If you get the chance and you also want to Thank @TJBaker57 and @budwich for their efforts in Posting their Diagnostic Guidance concerning the Electrical Problems with the Starter... You can run those same suggested Tests on the FUBARed Starter ON THE BENCH... WITH STILL SHOTS OF THE DMM RESULTS ... and then Post the results back here B4 you ask to have this Thread marked as:
Glad you finally sorted everything out and have a "Fresh START" on this matter!
Hobbyist4Life
94
Qatar
Well, of course I appreciate the help from @TJBaker57 and @budwich for suggesting tests that haven't come across my mind (which is why I started this thread in the first place) and @MRRSM for the in-depth informations and
However, I'm not sure what do you mean by FUBARed starter :undecided:
7,692
The Acronym FUBAR Translates in Plain English to mean:
F****d Up Beyond All Recognition... the add-on of the 'ed' indicates it as a Past Tense Event.
ANY Starter that Will NOT Start... Regularly and Reliably... Meets this "Technical Definition" ... :>)
Hobbyist4Life
94
Qatar
Well, we spoke too soon!
Today I took the Denali for a cruise, picked up a friend and basically kept driving. Got to a petrol station and found my car enthusiast/DIYer friend so I wanted to show off and shut off the car to show him the starter is working.
It seemed like it showed a low battery sign, but it did start in the end. Continued the cruise and turned off the car at a couple of places and started right back up.
However, when I reached home I shut it off and almost immediately tried to start it... NOTHING!! I cranked they key multiple times but still didn't want to crank, and no... I couldn't hear any clicks.
Kept trying and it ended up starting. After it started I've tried shutting it off and on a couple of times and it started right up each time after that incident.
Any thoughts?? This intermittent issue is frustrating AF 😤
7,692
#1 on the Repair Runway... is a Suspect Ignition Switch:
Here is a nice listing of Diagnostics and Ignition Switch R&R Videos on YouTube that are informative:
Incidentally... There can ALWAYS be More than One Cause for similar mechanical problems ...and they often will cluster together, Masquerading as One, Single Problem.
The "Low Battery" Indicator is probably an artifact of having Too Many Re-Start Attempts draining the battery down... without running the Engine/Alternator LONG enough in between these efforts to Re-Charge the Battery. Don't Forget to CLEAR THE CODES and read the OBD2 Scanner for Newly Stored Codes after Shutting Down and then re-starting the Vehicle.
budwich
2,043
kanata
good thing there is this thread on this forum to refresh your memory ... :smile:
As suggested do some tests / measurements when the thing works and then do them again when it fails... compare the results and go from there.
Check/replace in order of probability:
- Battery and connections
- relay (try jumping terminals when it happens)
- Ignition switch
- Neutral safety switch
TJBaker57
2,900
Colorado
Damned if I didn't come out of the store today and get into my Trailblazer and turn the key and......nothing. Well crap! Always have my bluetooth obd2 dongle in the truck.....started up the Torque App and in short order confirmed my battery voltage, park/neutral switch state, turned the key to start position and confirmed a "crank request" from the PCM. That led me to my starter relay which I already knew has had poor connections to the fuse block in the past and I had recently removed it for some testing of PIDS for the Torque App. Didn't feel like fiddling too much in the parking lot so I pulled the relay and jumped terminals #30 & #87 with a bent paper clip to start it up and drove home!
A point to be noticed here is you can test a relay while it is out of the vehicle and it performs OK. You can also test starter operations with a jumper wire like the video shows. But neither of these will test if the relay pins are actually making good contact inside the fuseblock. I found this to be an issue with mine 9 years ago when I bought it. My crank fuse socket also had similar troubles.
Maverick6587
730
Sterling Heights, Michigan
@TJBaker57 When I spent a week verifying that my fuel pump was bad. I removed the fuse panel, tore it apart, thoroughly cleaned it, and then used needle nose pliers to tighten those connections for the relays and fuses.
It took an hour or two but, now I know I shouldn't have to deal with that being a problem, hopefully ever again. You do have to use a drill to remove those bolts from the fuse panel, that's the only downside to it really.
budwich
2,043
kanata
before you go tearing into "things" that could make more problems, do the various tests that have been suggested to rule out lots of areas. Once those have been done, the "alternate outcome" could be things like "bad connection at the fuse box pins, wire joint, etc" but you shouldn't go there before doing some verifiable testing.
Another thing that has been done to improve relay contact in the fuse socket is to give the pins on the relay a slight twist.
Hobbyist4Life
94
Qatar
- As I have stated earlier, I have ruled out the chance of the ignition switch being the problem by swapping in the known-to-be-good ignition switch from my TB (R.I.P).. Which didn't make a difference.
- Actually no, the signs of low battery was after I drove for quite some time before I stopped at the petrol station and shut it off. The battery is new. However, the Alternator doesn't have a steady 14V output as my TB used to show. It goes anywhere between 13~14 (this is just looking at the gauge, actual minimum could be less than 13) during the trip.
When I start the vehicle cold, it's steady at 14 and then varies as I go. It's unpredictable, so I can't really "make it 14" when I want to. I've been delaying the thread for the alternator until I fix the major things, which I haven't mentioned all of them yet.
I'd definitely do that. Thankfully, it's been cranking everytime since after the lil' incident yesterday
- Ignition switch
- Battery is mentioned above, and the only cable that hasn't really been properly checked yet is the one from battery to starter.
- I'm pretty sure the relay is still working just as before replacing the starter. I will retry to jump the terminals when it happens.
- I've switched in the ignition switch from my TB earlier before I replaced the starter
- Neutral safety switch is fine as there's no difference wherever the shifter's at. Also, I can hear the fuse box relay engage.
Sorry to hear about your incident, at least it wasn't a big issue.
I've went threw the PIDs you listed earlier in the journey, but I don't recall seeing anything related to crank request or Park/neutral state :undecided:
I'm pretty sure the relay makes contact as I could hear it engaging before I replaced the starter
Of course! Never jump on the big things directly!
javier perez
