I was driving the truck today on several short trips, church, cvs store and then drop son to b-day party, shop with wife and then got a no crank no start issue. Gauges light up but no click (not even a single one) battery is just 2 yrs old and I jump started the starter via the relay (pin 30-87) trick method and starter is OK (thank goodness) truck will run with this trick.. once home I replaced the ignition switch since it's $33 and a 10min replacement.. still no-go and then left it later to do some other work (decal removal and replacement on the liftgate... maybe the chevrolet decal is bad luck,,, have to replace it with gmc) Once I'm done with the decal which is like an hour, the truck started fine.. and tried doing it several times whenever I have the chance and it's been starting well.. I'm not sure what happened but could it happen again if the weather is hot (no start happened at 1:30pm which is hot, then I have to do replacement at 4:30pm which is still hot but the engine has cooled down already...
Wife is now not so confident driving this truck..
