- Dec 6, 2011
- 779
As most of you know, I am pretty anal about handling and brakes. When switching to my winter rims on our 04 Trailblazer LT, I noticed the pads were getting down a bit so I popped off the caliper and looked at the pads. The NAPA Adaptive One pads still had lots of wear left (about 20,000 km since I changed them) and as usual, the inners were worn more than the outers. The inner side of the NAPA ultra premium rotor was also worn more than the outside, leaving a noticeable ridge on the outside where the pad doesn't touch. This is again pretty normal in northern areas because the salt eats rotors more on the inside than the outside. I have new rotors and pads sitting in boxes, and might wait for spring to replace. I am also thinking of replacing both calipers. (Just for fun, I went to AC Delco OEM coated rotors and Akebono ProACT pads.)
There is no indication that the calipers are bad, but there is that uneven wear on the inside versus outside pads that indicate the pistons may be getting a bit sticky. Until now, the only way to replace them was Cardone remanufactured calipers, and paying the core charge and then shipping the old ones back. New factory calipers were stupid expensive. But Raybestos has recently started making brand new calipers and selling them as the highest premium level caliper you could get. Part numbers are FRC11237AN and FRC11238AN. The Raybestos Opti-Cal calipers come with all hardware and brackets. (Part numbers for the EXT model is FRC11237N and FRC11238N.)
Interestingly enough, I found out AC Delco Professional sells the exact same brand new calipers made by Raybestos. The Rock Auto catalog is incorrect; they list the AC Delco as a remanufactured, but that is wrong. They are in fact the same as the Raybestos ones. Part numbers are ACDELCO 18FR1891N and 18FR1893N. EXT models (with the different bracket) use ACDELCO 18FR1892N and 18FR1894N. So if anyone is looking for new calipers, save some money and get the Raybestos brand instead of the same one branded AC Delco.
The nice part is that because they are brand new, there is no core charge.
Any views on remanufactured versus brand new? I know remanufactured can be hit or miss, depending on the quality of the original part and how many times it has been rebuilt. In Canada, NAPA also sells the premium coated Eclipse calipers remanufactured by Cardone for about the same price as the new Raybestos (plus a $65 core charge.)
So new Raybestos Opti-Cal calipers versus remanufactured Cardone coated calipers?
Once you change out the pistons, seals, slider pins, bolts and bleeder screws, is there anything in the body of a reman that can actually go wrong? I just don't know how "premium" a caliper can get?
