New Set-Up : 315-70-17 TreadWright Guard Dogs and 17x9 Pro Comp 6032
Finally got some good 35's to run and some new rims to replace my ones with some issues.
The new set-up is a set of 315-70-17 TreadWright Guard Dogs. Basically the old MTR tread on a BFG AT Carcass. These carcasses have the 3 ply sidewall. The unmounted height is right at 35 inches. The weight was about 76 lbs a piece. Actual tread measures about 11 inches wide. Which is interesting since the previous 305's were wider, but 315 and 11 inches seems to be standard.
The wheel are the Pro Comp 6032 in the new HD Chrome. There are a bit over 20 lbs and the size is 17x9. I like that the plastic center caps are bolt on. These wheels are light and the finish really is incredible. I think black rims look like cheap ghetto crap, so I knew with the discontinuation of the Knight Chrome I had to go with full chrome. My chrome wheels always get me home and dont look like spares doing it.
The combo gained me about 1.5 inches of ground clearance. The tires being a bit skinnier makes the truck seem taller and narrower, not a bad thing. The wheelwells are filled out better, but may have additional rubbing, although I doubt it is anything of consequence. My rear extended control arms do not appear to center the tires in the wells. Looks like an extention of more than 1/2 inch would be more appropriate, but Fishsticks said his 1 inch was too much.
I only drove around the neighborhood, under 30 mph, and these tires make more noise than the worn pro comp xtreme mt did. They do feel solid and smooth. Truck feels taller, but is very planted and not unstable feeling. Time will tell.
But what people want to see....pictures....
The rims and tires..
Old in front of new
Old
New
Some Measurements
Old Height
New Height
Old rear
New rear
Clearance to cut front old
Clearance to cut front new
Tire to fender clearance old
Tire to fender clearance new
And just some pics of the stance and such
Regulator
2,496
you're giving harmless a run for the title of picture whore! :tongue:
Looking pretty good!
Sent from my SCH-I510 using Tapatalk
14,950
I pretty much think he has taken the title from him so far.
I like the look!
So Now I have a few miles on the Treadwright Guard Dogs....Honestly....Not impressed. They are loud and not just mud tire loud, they are annoying and at a pitch that gives me a headache. I love the lower rumble of Swampers and the typical mud tire howl, but this sucks. Not sure how no one else has mentioned this. I also get a weird vibration/feeling/sound like one of the tires is oout of balance, but only occasionally and at weird speeds. Does not inspire confidence in the tires. They pick up a ton of gravel/rocks. Far more than the Pro Comps did.. They also seem to hold these rocks until speeds are enough that when they release they slam into the truck and scare the crap out of you. The lack of sidewall tread is annoying to me, just a visual/preference thing as they have not prevented me from anything, but I really cant like the looks of the tires.
They do ride ok most of the time. They were cheap. They seemed to balance ok, but really think I need them rechecked since it while it is only occasional but the unbalanced feeling sucks. Lots of people do seem to like them on the truck, but not me.
I wish I had spent the little bit more and got different tires. The noise of these has gotten worse as they wear and ruins long drives. I would recommend them to someone on a serious budget that does not mind the looks and noise, but for most people investing as much as it costs to make the truck fit 315's or 35's...dont be cheap on the tires.
Pittdawg
538
Bummer. Nice rims though. Maybe you can sell your tires to some poor sap...
Opeth
177
For the extra $250-300 over the cost of the tread wrights, I think I will just hold out and get the Destination MT's I've been eyeing after seeing this. Figured the cost was too good to be true, thanks for the updated review.
No problem. Kinda why I posted it. The tires are not bad, but when you are really spending money on your ride...Buy what you want or you could end up regretting it like I am. No safety issue or really horrible things about the tires. They are not exploding or coming apart as some people say retreads will. Just a cheaper tire and I now know why. For a non-DD or a dirt toy they are great. Just not what I wish I had.
I have ran several sets of MT's...Firestone, BFG, Pro Comp...and several different Swampers...LTB, SX, Thornbirds, SSR... plus many other tires.
Bartonmd
545
I wouldn't say they're "too good to be true" at all... Old MT/R pattern, which is better in the snow and probably rocks than the Destination MT, but also makes a different noise. Having had the Destination M/T on my truck, and having to cut and sipe them to make them useable in the winter, and not being able to hear the 12-valve Cummins over the tires, IMO, it's a 6 - 1/2-dozen thing... It may or may not just be that size that has that pitch. I never noticed any kind of annoying tire noise in Regulator's truck, with the TW tires...
The one thing that they're not going to be able to do is get real, hardcore side tread... Just because of the process of the re-tread, and where the cap stops, they're not going to be able to do it.
Still, I wouldn't say they're "too good to be true"... It's just what they are... 1/2-2/3 the price of new tires, for re-treads, and what comes with that.
Mike
I'm still curious about their Sentinel or Warden AT tires. I've been extremely happy with my Firestone Destination AT tires at least for what I've used them for. They've had good grip and wear has been exceptional. They are rated at 50k, have 40k on them, but sure don't look it. I haven't really done any offroading to know how well they do that but being stock height and stock size tires I'm limited there anyway so I haven't even tried.
Maybe if/when I get a lift I might just get more Destination ATs in a larger size. The price of the Treadwrights is certainly alluring.
How well have those Treadwrights worn compared to other tires and how has the grip been aside from throwing rocks all over?
Bartonmd
545
I have the Wardens on my Cummins. I've only had them on for ~7-8k miles, but they are pretty much like the BFG AT. Little noise, good all weather traction, etc.
Mike
Regulator
2,496
I am honestly surprised Kyle. I have had just the opposite experience with my 285/70-17's. They have been reasonably quiet until recently, now that I am at about 40k miles on them I am noticing them getting louder as the are wearing down. I had zero issue in getting them balanced, and even ran them without any weight for a while after initially mounting them myself. For the price, I am more then pleased with what I got and will be purchasing another set later this year as mine seem to be approaching the end of their life.
I should also point out that this is my first offroad built vehicle and I have no real experience with any other tires. Just stating that I have been more then happy in my experience.
Mike
How is the hydroplane resistance? I'm still a little paranoid about hydroplaning after my accident in my old car nearly 2 years ago.
Bartonmd
545
It's great! I haven't hydroplaned in my truck, or with the real BFG AT on my TB, once...
Mike
I have not had any hydroplaning either.
navigator
504
I wonder is anyone else running the 315 TW like Kyle is? Did Donny run those for awhile?
I think I have heard of 1-2 issues of the "cap" look like it was separating that they took care of quickly but I don't think I have heard of anyone unhappy with the tire itself/noise/ride.
Fish has them on a 35 12.50 17 KM2 carcass, which I asked for but got the AT instead...I even waited for the right carcasses and they did not send them, but whatever. I dont think he has mentioned any issues with his and I really dont have issues with mine other than the noise and feeling of settling for less tire than i wanted.
06_4.2_4x4_ls
