New Guy from Maryland
GeckoEnvoy
5
Hey all!
Just wanted to introduce myself to everyone, as well as help others and learn from all :smile:
First off, I'm Dennis and I'm 19, in college majoring in Mechanical Engineering. I've always been a car guy, so it's mostly why i'm majoring in that.
I have a 2003 Gmc Envoy XL SLE that my parents bought new back in 2003. Basically my parents gave the truck to me when I got my license lol. Currently is has about 150,000 miles on it and it is running strong still.
Parts that were replaced over the years with my dad:
- Mufflers, Headers (Still has exhaust leak, but we sealed it up)
- Bearings
- Coils
- Suspension, both front and rear
- Headlight housings
- Fuel Pump
- Heater cores, both front and rear
- Fan Clutch
- Power Steering
- Transfer Case Motor
- Water Pump
- 3rd Brake light
- Drivers side reverse light (Some teenagers smacked into the bumper and ran off, luckily there was a witness) Damage is still seen on the bumper though.
- Rear Glass (Shattered because the shocks on the glass were old and getting sticky, I pushed a little to hard when opening it)
- Exhaust Cam Position Actuator Solenoid (Still leaks some oil)
I'm pretty sure there's some other stuff, I just can't remember lol
Interior:
-Aftermarket Speakers
-Added a JBL Subwoofer 12"
-Aftermarket Headunit
-Added backup camera
Overall the truck runs smoothly. I literally grew up in this truck and I love it. Hope I can learn from others and provide help as much as I can!
-Dennis
littleblazer
9,265
Welcome.
gpking
534
Berkeley Springs, WV
Welcome!
You aren't my doppelganger by any chance?
Same age, same model year, same state, etc.
I'll be studying at UMBC this fall, so perhaps our vehicles will cross paths at some point. :thumbsup:
If you haven't already, check out the "Member Map". There's a few other Marylanders on here.
GeckoEnvoy
5
Thank you all! I will post pictures soon, truck is currently dirty so I'll find some pics.
gpking said:
Welcome!
I probably am lol! I'm actually studying at Penn State, but I come home frequently, so maybe I'll see you on the road :biggrin:
And I will take a look at the Member map!
GeckoEnvoy
5
[sharedmedia=gallery:images:1078]
[sharedmedia=gallery:images:1077]
That's pretty much all the pics I have now, I'll add another one this Friday when time allows :smile:
Bow_Tied
453
London, ON
Welcome!
swede
1,576
A big Welcome from the Swedish chef
Robbabob
1,096
Welcome to the Nation! Glad to have you on board!
When you're ready, let us know you've changed the Transfer Case fluid every 50,000 miles, and the differentials at 100,000 miles.
Curious, I've not seen many comments on failing power steering. Was it a leak, or failure?
GeckoEnvoy
5
Thanks again!
Oh I forgot, the differential fluids were changed around 110,000. I'll have to check about the Transfer Case.
As for the power steering, I noticed that the car was getting harder to steer during later fall of 2013, but I thought it was normal because I had it in A4WD (lots of rain and snow during that time). Then one day it was reallyyy hard to steer, so I asked if my dad could finally drive to 'feel' it. It was just a failure, after the new one was put in the steering was smooth as silk.
Reactions: Robbabob
Robbabob
1,096
The heavy experts in 4x4 say never to drive it A4WD as the blah blah plates (or what ever they are called) will go out. They suggest getting good tires on the truck and leaving it in 2wd or using 4HI when conditions warrant. I am no expert, so one of them will chime in to add advice on this.
Thanks for the info on the power steering! Glad it worked out.
Reactions: GeckoEnvoy
GeckoEnvoy
5
A4WD only kicks in the front wheels when the rear wheels start slipping. Although, driving it in 4HI on dry pavement for a long time can cause damage, worse if in 4Lo. But that's just from what I've read with my dad. Transfer case is still fine.
Mark20
1,630
Welcome aboard!
People have lost control due to the A4WD kicking in and suddenly gripping when you're already try to deal with a bad driving situation.
marinegrunt
110
From what I've read on here there's an undersized bearing in the t-case. That bearing sometimes fails when in AWD. It's caused from the front tires engaging and disengaging when going back and forth from dry to wet pavement. They ended up coming out with an updated bearing because of all of the failures. That's why it's recommended to not even use AWD. You won't have that problem if you're in 4hi. Just use it when you need to and put it back into 2wd when making sharp turns on dry pavement to prevent crow hopping.
One of the guru's can explain it better than I can.
Welcome
MEHMET ONUR
