- Joined
- Dec 4, 2011
- Posts
- 12,927
I need to replace my AC pulley bearing and I need to remove the fan and shroud to get enough room to do so.
My Haynes manual mentions when removing the fan and shroud as a unit that a special GM tool 46406 is required, but then makes no mention of its use in the actual procedure. What is this tool and is it really actually needed?
It also isn't very clear when it comes to the part about actually removing the shroud and fan. It says to tip the radiator and condenser forward to gain more room, but it doesn't say HOW the radiator is mounted that allows it to be tipped forward.
Can anyone clarify? Or maybe, is there an easier way to do this job without having to screw around with the fan and shroud?
