HELP!!!!! I'm on my 8th day of looking into this issue and it's driving me nuts. Bear with me, I may get wordy.
2003 Envoy XL 5.3 V8
Background: About 2 weeks ago my Waterpump gave up so I had it replaced by a local shop (Not my typical shop). I was not able to drive it far because of overheating. After it was replaced for what felt like a wallet rape they told me that a lot of coolant had got onto the belt and it would stop after some time. It wasn't going away and the noise started getting louder with now a howling noise which I figured was the power steering pump.
I replaced the power steering pump myself and the next day I replaced the belt. 2 days past and it was very quiet but the noise came back. I took the belt off again and cleaned all the pulleys and lubricated them. Each time I did this the problem came back the next day. If I sprayed the pulleys the noise would go away. Yesterday I took it to an alternator shop to ensure the alt wasn't an issue. The guy listened to the noise and said. 1. it's not coming from the alt. 2. it sounds like something is stuck and scraping as it rotates. Using a hose he could tell the noise appeared at the tensioner pulley. So I replaced that tonight and behold, I still have the F%#king sound.....
I took the belt off again and started the truck. No sound appeared so it is definitely related to the belt or an accessory. I also used belt dressing on the belt and if I spray the flat side there is not much change, If I spray the ribbed side the noise gets worse.
I read somewhere that there are different size belts and also that people have had issues with Dayco belts which is what the parts place had. Can anyone tell me the proper length for a XL v8?
