- Dec 12, 2011
- 4,656
Thanks @xavierny25 for the tips on removing the front brake hose.
Once removed I was able to heat the fitting and loosen the coating so all is good.
I purchases the SS (stainless steel) lines for the TBSS (Stop Tech 950.62013) and it appears to mount the same, but I don't see how the right side will work as it seems to be too short when turned to full lock. The calipers and brackets are for the TBSS also so mounting point is the same.
Is the TBSS steering knuckle different?
The front mount I can make work...
However the rear I don't see how it will work.
For time being I can use one mount, but surely don't want to keep it that way.
The other issue is the factory metal tab that holds the ABS sensor, I can heat that and remove it from the OE hose.
