- Jul 22, 2015
- 2,724
This thread continues my quest to enable tow/haul capability. I'm now at the part where I need to build the mechanism - and since I'm not really facile with doing this on my own, I'm looking to contract this out. Figured I'd start here, given the audience
I need this built - as you can see, it's pretty simple. 1 relay, a couple of capacitors, three resistors, an LED, and a CD4013 'flip flop' (hey, TI calls it this; don't blame me), all done up on a small PCB.
I will provide the switch from my end, and I'm leaning toward using a momentary, if possible (if not, I don't mind hooking up a physical toggle (DPDT?)
If you're interested, contact me via PM. I will pay for all parts (I can order them, if desired), *and* I will pay for your labor to put this all together (name your price, but please don't gouge a fellow GMTNation member, just because he is too dumb / stupid / lazy to do this himself!) Yes, I am serious about doing this.
Looking to do this fairly soon if possible, as I'm going to be taking the trailer out very soon to 'points west'
Once it's built, I'll connect it to pin J-71 (blue) on my PCM. After exchanging e-mail on this w/ Jeremy @ Lime-Swap, I found out that this should be 'enabled' from the moment I connect this up - *no* programming needed (remember, I have the 5.3L, but if you 4.2L guys are interested in this, the info is out there somewhere, I'm sure).
I got the info from an F-body forum; they use T/H for racing purposes. The schematic is actually from a French-based F-body board (hence, the French text).
Finally, one other thing I chatted w/ Jeremy about - Flex Fuel capability for the 360 V8s. It's 'do-able', but may be some trial / error involved (more on this in a separate thread, if anyone's interested - trying to keep this one on-topic).
