Need a GM Part Number. . . . .HELP
02tahoelt
60
I need the part number for the PLASTIC radiator support cover that the TBSS uses
Thank You
15234014 Baffle, radiator air
02tahoelt
60
Thanks, You seem to be the Man around here
Is there a direct bolt-on e-fan, that bolt on to existing bolts not electrical
Well, I just learned to Google the old site whenever I need information that isn't here (yet). :wink:
Not sure what you mean by a non-electrical e-fan. By definition they are electrical, and don't bolt to the existing water pump mounting holes. There is a new non-electrical thermostatic fan clutch that you can install, but then you'd need a PCMforless tune to get rid of the error codes. Not that a PCMforless tune is a bad thing - it's HIGHLY recommended.
02tahoelt
60
That's not what I meant, something that bolts to fan shroud existing spot, I know I'll need a tune and probably splice into some wires. Am looking for E-Fan, Lol
Like my Tahoe E-fan was easy unbolt fan shroud and remove fan clutch and just slide in fans from 2005 and up, and bolt right back up, same thing some wiring required.
jvest
