- Dec 4, 2011
- 12,927
From what I understand the 2002 - 2005 GMT360 PCM cannot be tuned for tire size. I know some people had played with doing it but the consensus was it isn't possible. Why is this? What happens when you try?
The most common 16" tire size to upgrade to when lifting is 265/75/16, which is a 31.6" tall tire, vs the stock 28.5" tire. Now here's where I started musing, plus I'm a little tired, so be warned
Stock tire circumference is 89.7 inches. The upgraded tire is 99.4 inches. So we're looking at about 10.8% increase, which means if nothing else is changed the speedometer will be reading 10.8% too slow (reads 60mph, actually going 67mph). This also means the odometer isn't putting on the miles fast enough.
The most common gear ratio is 3.42. A 3.73 gear ratio I've been told seems to be a better fit for these trucks, particularly when lifted with the bigger tires. That ratio is about 9% lower. If you change the gear ratio without changing anything else, the speedometer reads 9% too fast (reads 60mph, actually going 54.6mph). Odometer is now racking up miles faster than reality.
So... What if someone crazy (like me) was to put the taller tires on and change the differentials? They should counteract each other, meaning the end result would be the speedometer and odometer would only be 1.8% too slow (reads 60mph, actually going 61.1mph), plus I'd have the better gearing.
I already replaced my rear axle once when my old one was worn out, and I know the front is a huge pain to swap out, but it was just some ideas rolling around my head. I guess if I was to have front diff issues that required me to take stuff apart up front it would make more sense to do that then.
Anyway, any thoughts on this or am I totally whacked out and need to get some sleep
