Might add a light bar or hook up the small sub I had that was left in the Cutlass when I bought it.Both those guys. Also a local shop should be able to build you a beefier alternator... if they exist still. What are you looking to do if I may ask?
Oh, unless it's some wicked power I wouldn't worry brother.Might add a light bar or hook up the small sub I had that was left in the Cutlass when I bought it.
Forgot to mention an efan setup.Oh, unless it's some wicked power I wouldn't worry brother.
Unless you had every thing wide open at the same time I wouldn't worry.Forgot to mention an efan setup.
I was running 2 12" Rockford Fosgate R1 subs with a Rockford Fosgste punch amp, and my halogen KC lights with ease. I wouldn't stress about it too much, brotha.Might add a light bar or hook up the small sub I had that was left in the Cutlass when I bought it.
Not not stressing, this is hypothetical. Unlikely I'll do it. Money is too tight for much mods.I was running 2 12" Rockford Fosgate R1 subs with a Rockford Fosgste punch amp, and my halogen KC lights with ease. I wouldn't stress about it too much, brotha.
I've been running a volt meter for years, was one of the first mods I did. I got it back when the OEM alternator was crapping out.I'd strongly recommend a volt meter like the SMD VM1 http://www.wccaraudio.com/default/s.../volt-meters/smd-12v-volt-meter-smd-vm-1.html as the volt meter in our dash is super slow at updating and might seem like you have good steady voltage but it actually is bouncing around. I have the VM1 in my trucks dashboard along with my touchscreen I fiberglassed in (I put the VM1 in the hole where the rear wiper switch went since I never use it) and I can see the voltage bounce around on the VM1 but not the meter in the instrument cluster.
I'm not worried either, a voltage gauge is a real-time quick visual reference.I don't need a volt meter, I listen to the blower. actually I use torque a lot when I have an issue so that works. It runs my inverter at 1100 watts woth everything off so I'm not worried... your car man.
