2002 Trailblazer 4.2 have many tranny codes. Someone said check fuse 47 and did. 8.0 volts and fuse.
Gas milage about 6mpg.
Is there a possible relay that is bad? Found some bad relays for lights and the starter relay was thrown in the glove box.
mwolvie@gmail.com rear fuse box (back seat} fuse 47 has power but only 8 volts not 12 volts.No relays. The solenoids and TCC clutch are driven off a single power wire from ignition. Post ur MY and I'll tell you the fuse #. Also, what do you mean about 8.0V in the OP?
