Voymom
- Joined
- Feb 3, 2012
- Posts
- 2,523
I have been a bad Voymom as we have put a lot of stuff on the back burner as far as maintenance goes(due to wedding planning eating our finances). So Starting October 26th we will be going down our list of things that should probably be done before the first big snowfall. I was wondering if anyone would chime in if I forgot anything that is or maybe of importance, and a little help with prioritizing which things should be worked on first and so forth. Some things, like lubrication, I just grew up watching my dad have done to his vehicles before winter, not sure of the importance of it, but if it isn't needed just let me know.
Thank you!
New ceramic brakes(1/2 worn but very noisy)
New rotors all around
New rotor shields all around
New tires all around(a little less than 1/2 tread left) Also need recommendation on a good tire brand that works well with these trucks(prefer all weather tires with good high speed ratings and wear ratings)
Service 4x4
New end links all around
New shocks and struts all around
Alignment
Power steering fluid flush(It's dirty, PS pump replaced in March)
CV joints/boots checked
Lubrication
Rubber mats
Top off fluids
Spark plugs
Fan clutch(maybe e-fans with PCM tune)
Truck has 121k on it, the only things we replaced were the PS pump, water pump, thermostat. We run Mobile 1 full synthetic. Not sure of the tire brand on it now, but it seems to wear down fairly quick.
Thank you!
Service 4x4
Alignment
Lubrication
Rubber mats
Top off fluids
Spark plugs
I do appreciate the help Kyle!
