STLtrailbSS said:your ball joint angle will be pretty bad until its accompanied with the Modified A Arms. You could hit some stuff with pb blaster tonight if you have rust. Replace the strut mounts if you can it literally has no downside to do it.
xtitan1 said:Well a downside would be the cost of new strut mounts. What's the upside (honest question not arguing here)?
STLtrailbSS said:If you look at a strut mount depending on mileage the rubber is eaten up. By replacing while you have the strut off you are killing 2 birds with one stone. You are replacing a part which most likely have some nasty wear existing and doing it while you had to take the part off already....advanced auto coupon code and $40-$50 put them on and don't worry about them.
To original poster do it yourself me and JR have already lowered ours and can answer any questions it's literally some bolts. And a spring compressor. Breaker bar and a 1/2 ratchet if you have air/power tools you just made it even easier.
Snailblazin';202439 said:You don't NEED the modified upper control arms with the BellTech drop struts and STOCK springs provided you install the correct supplied spacers.
bbarker89 said:If i lower it 1.5? is that going to make a big difference?
jrSS said:U should beable to get an alignment close to spec depending on if the shop knows what they are doing without arms with a 1.5" drop.....but your upper balljoints are gonna be screaming for mercy. The arms not only get your lowered rig in alignment...they also fix the balljoint angle issue that arrives after lowering. If i were u....I'd do it right and buy the arms...its your call. Plus a 2" drop looks a little better than a 1.5" drop
bbarker89 said:drop her today. so excited. i guess itll take some time to settle? ill post pics tomorrow in the day time. it took about 5hrs.
jrSS said:Some nice wheels will set off your new stance.. looks good!!
bbarker89 said:yes i have air/power tools. whats a breaker bar? ive seen on tbss the scotts collar install is that the same concept?
and why dont i need jdm modified arms? everywhere ive seen you need them i personally havent purchased them but i will if need be
TexazReece said:Nice Bro, let it settle and see if it'll even out. What type of 20's are you going for? Factory tbss, repos or aftermarket?
NORCAL SS said:with my arms will be nice.
