Lower control arm bracket problem
chopper320
25
This weekend I’ve been replacing a lot of the front end parts on my 05 trailblazer and I I’ve run into a problem on the drivers side lower control arm bracket.
When putting the new one in, one of the nuts that appear to be welded on the frame that the 3 bolts go into, broke free. I also cross threaded it. I now have the nut out but I’m not sure what I can do. I’ve looked everywhere and I don’t think there is a part number for that nut. The bolt can be bought but I think the nut is considered part of the frame. I also don’t see any way anyone could get in there to weld it back on.
Anybody have any suggestions?
Thanks
It is part of the frame so it's not available from the dealer. You'll have to go to a fastener supply store to get one or they can get a nut and bolt similar in size you can use instead. Bring your bolt with you. Hopefully you can get access to the top side so you can use a wrench to hold it on top of the frame while tightening it and you'll have to let the alignment shop know about it.
valleyhopper
1
Iowa
I was in the process of replacing my lca bracket and the bolt snapped off in the frame what's thd best way to remove it?
Reactions: Rfritz7447
I had the front bolt do the same to me. I had to torch the head off and get a nut and bolt to replace them.
Rfritz7447
1
Michigan
Does anyone know the size of the nut welded on the frame. Mine came off but its not stripped. If there's enough room I'm pretty sure I can get a wrench in there.
7,639
Post #22 & Post #25 for the Bolt Specs & Dimensions... and this ENTIRE Thread is worth Reading from End to End:
MissCrutcher
