- Mar 19, 2014
- 91
2002 Trailblazer 4x4
Trying to replace drivers side lower ball joint.
For the life of me I can not get the ball joint to separate from the steering knuckle. I have the ball joint fork and I can wedge it in the whole way and it will not loosen. It is in to where the fork is bottomed out and does not move. I have a feeling the ball joint is so bad that its just moving the lower control arm and not pulling the ball joint through the knuckle. (Yes I did remove the nut on the bottom lol) I even tried tapping up and nothing it is like it's threaded or something in there.
I guess only solution is like a 3 jaw puller perhaps and press it out that way?
Any help is greatly appreciated it.
I did the upper joint ant that was a piece of cake compared to this.
