Re:
@Mooseman 's observation about the recent New Harness Purchase by another Member:
https://gmtnation.com/forums/threads/2007-engine-pcm-harness-compatibility.17927/#post-550606
As for the lack of 'permanence' to the setting of the P0014 Trouble Code... This part of the system is subject to the vagaries of variable Oil Pressure that does away with the need for an EGR style of control...and provides a wide band for torque in a surprising manner that allows this unique in-line (6) Cylinder Engine to produce so much Horse Power. However... when the CPAS gets clogged..or its in-dwelling metal screens disappear.... then the Cam Phaser cannot react within its 25 degrees of advance and retard ...and it begins to stumble...especially at idle and looks more like a "Bad Tune Up". While the P0014 is specific to the CPAS... All of the players involved are on this list:
(1) PCM Ring Leader of this Circus
(2) CPAS Uses signals from the PCM to vary the Oil Pressure entering or leaving the Cam Phaser
(3) CPS Senses the ACTUAL position of the Camshaft vs. the VARIABLE position of the Cam Phaser
(4) CKP *** Senses the ACTUAL position of the Crankshaft using Reluctor Notches to locate it while rotating
If the Harmonic Balancer Bolt loses its holding power (110 Foot Pounds Plus 180 Degrees of added rotation to meet TTY Specs) then the P0014 may also have a P0016 Code... and much bigger engine problems will happen if that event is not soon solved.
Of all these parts and pieces... the ONLY one that is independent from actual sensor signals in any way is the CPAS ...and so it is the very condition of the Motor Oil....or an Oil Infected Connector...or Missing CPAS Filter Screens that can ruin its reliability. One other very important thing about the "leaking "O" Ring on the CPAS" has to do with
a flaw in the method the hole or port that the CPAS fits inside of actually is INCOMPLETELY bored through... it fails by about 1/8" on the very inside of the Engine Head. You might notice that there is a gap between the 10MM Bolt Up Bracket and the outside edge of the Aluminum Head... Well having taken down two of these GM 4.2L LL8 Engines... I noticed that in both cases... as the CPAS Solenoid violently moves the internal pin that routes back and forth to shuttle the Engine Oil into and out of the Cam Phaser... in the same way that a Rocket moves in the direction opposite the escaping rocket nozzle burning fuel... the BODY of the CPAS likewise reacts in moving back and forth causing it to slam against the inner edge of that unfinished machining...and gradually.. that residual incompletely bored soft Aluminum metal begins to Crack and Yield... cracking very slight;y ...but just enough to allow the BODY of the CPAS more freedom to bang back and forth inside of that tube.
The resulting "sliding" causes the Sealing "O"Ring to flatten out and wear down enough to leak out Engine Oil...hence the Failed CPAS problem and the strange Black Streak of Oil all down the Right front Passenger side of the Engine Block. Had the CPAS Tube been completely bored through the head... then the CPAS would be able to completely lay flush...and the 10MM Hold Down Bracket would prevent the CPAS Body from moving even slightly. If you would like to observe just how much force that internal solenoid can generate... just hold the CPAS in your hand and hook up two wires applying 12VDC to it...and Hang On. Here are the images I took as proof of this very problem:
