About two months ago, I had an issue with my passengers side low beam headlight going out. I immediately replaced the bulb and it started working again for 3 days. Went out again, replaced again and this time I checked the connectors/sockets to the bulb. Both the drivers side and passengers side were burnt. It's worth mentioning the drivers side bulb has never gone out. I cut off connectors and replaced them along with 2 new bulbs. I thought the issue was fixed until today the passengers side went out again while driving home at night. I've searched youtube and different forums and this is obviously a very common issue for different years. Most common suggestion is replacing the relay. I checked #45, #46 relays and both look to be the original GM with numbers on top.
What would you guys recommend as far as troubleshooting steps? Again, the only thing I've tried is replacing the connector and bulb(s).
I do have a digital multimeter just not sure where to start.
