Hey guys. I am an old member from "that other site" and heard a lot of folks had migrated here. I am having an issue and hoping that you guys can help....
I have two issues actually. Both of which are driving me absolutely nuts!! I have had two mechanics look at my car, read countless forums posts for similar issues and also took it to an exhaust shop and no one can seem to tell me what is causing these issues. They could be related but I don't think that they are.
Issue #1
The engine is shaking violently but only seems to do it when the vehicle is still (P or N) There is an obvious movement to the engine when looking at it with the hood up. Sometimes it is worse than others. I have no SES codes nor a SES light. I will post below what I have tried so far.
Issue #2
When I accelerate and only when the car is above 2500ish RPM's, it makes a VERY loud whining noise that to me, sounds like it can be heard through the exhaust but that could just be my ears. As soon as the transmission shifts gears and the RPM's go back down under 2k the noise is gone and the engine purrs like it should. I am completely out of ideas.......
I have tried the following:
1.) Replaced the alternator.
2.) Replaced the idler pulley.
3.) Replaced the Water pump.
4.) Replaced the fan clutch.
5.) Replaced the tensioner and pulley.
6.) Replaced the serp belt.
7.) Checked the pulleys and fluids for the PS pump and AC.
8.) Cleaned the throttle body.
9.) Replaced the Air Filter and fuel filter
10.) Replaced the coil packs, boots and plugs. 41-103's
11.) Checked the bolts on the intake and exhaust manifolds.
12.) Replaced the motor mounts and brackets with OEM parts.
13.) Replaced the catalytic converter.
14.) Replaced the thermostat
With the belt off, I drove it around the block. It still vibrates\shakes and still has the loud whine.
Before Installing the new cat, I had them put a piece of test pipe in its place and it only seemed to amplify the sound.
Issue #1
Issue #2
