Loud buzzing noise from speaker mounted on steering tube?
Sprung Monkey
350
Al
Note exactly sure what caused this I was towing 3KLB trailer.
Stopped for a rest then restarted engine then buzzing so I disconnected
the two wires going into this small speaker mounted at steering tube.
What was this some sort of over heat protection to either turn of the engine or overheat?
The temp guage on dash is normal temp.
Should this speaker be reconnected?
Thanks SM
10,679
Sounds like something aftermarket. Any chance you can take a pic of this speaker?
Sprung Monkey
350
Al
Low buzzer could possiablley be a messed up GM burgluar alarm.
I’m thinking it has something to do w/ the echo/sounded backup warning sys.
I removed this echo sounder sys. 2 years ago.
bobby2175
