- Dec 12, 2011
- 4,681
I plan on getting an exhaust pressure test this week but the downstream O2 sensor is all over the place and the outlet temp is about 100 deg below the inlet. Been concerned about a 1-2 MPG drop on the DIC when I'm steady cruising, flat road @ 60-65 and I'm getting 19-20 MPG when I normally would see 22 ish. Could be slightly clogged as well and I have no codes and just recently changed the original upstream sensor which is likely a culprit to the ill-health of the cat.
I personally like Magnaflow, just would like opinions if anyone has used others, direct-fit specifically.
