Okay, so I have a 2004 Trailblazer EXT with the 5.3 V8 (VIN code P) and I'm having an issue idling.... It's starts and runs fine for the most part... The problem comes in heavy traffic and at stop lights... My RPM's are dropping too low.... They go down to around 450-500 and it will stall if I don't toss it in neutral and manually raise the RPM's with the accelerator pedal. This problem does not show itself until the engine is warm (after about 15-20 min)... When I first start it up, it runs fine and RPM's are normal.
I've had it to the dealership now 3 times and they haven't been able to get the problem fixed.. I have new plugs, wires, MAP sensor, air filter, new battery, fresh synthetic oil and a new O2 Sensor.
I see alot of people having the same issue and they suggest cleaning the throttle body and another solution I found was to change the Cam actuator solenoid valve....
I have no idea where the CAM solenoid is and was wondering if someone could show me on a diagram...
When it comes to the variable valve timing solenoid, I'm a bit confused... I am finding some sellers that offer 2 of the VVT solenoids, one for the exhaust and one for the intake... Do I need to buy the set and where are they located?
