Leveling Buick Rainier AWD Questions
02Olds
91
Looking to level out the rear bags on my Rainier. I've read Norcal SS's threads and seen the video, and from that I have a few questions.
1. Since my Rainier is AWD, do I have to keep the rear end a bit higher than the front because of this? How much higher, if so?
2. With the suspension leveled, will my headlights be pointing too high, so I would have to re-adjust them?
3. Will my ride suffer if I level it? Obviously I'll cut the bump stops, so I won't be resting on them.
4. After this is done, are there going to be any alignment issues?
Thanks guys!
jrSS
Mine is at 30.5 with bag adjustment. No need to adjust lights. Ride will suffer the lower you go. Mine rides fine. I added beltech shocks. You can just use stock shocks since your just trying to level it out. Good luck!!
chevytruckdude34
