LED Brake/Blinker/Reverse Lights Upgrade, Help.
Cable810
690
I've been surfing the web tring to find LED Brake/Blinker/Reverse Lights for my TB. I was on Jettt Auto Tech and just about fell over when I saw the prices(No ofense to anyone). The bulb size is 3157 for all 3 bulbs in the Left and Right Tail Light. Looking at Superbright LEDs they have 6 selections of the 3157 Bulbs. My question what one do I get??? Instalation is straight foward, but selecting a LED is(for me) a bit harder.
http://www.superbrightleds.com/cgi-...ction=DispPage&Page2Disp=/specs/315x-xLX3.htm
If you have anyother LED 3157 reccomendations let me know :thumbsup:
DJones
701
St. Petersburg, Florida
I have the 315x-x18-T 18 LED tower bulbs from superbrightLEDs.com. They are perfectly bright, and the nice thing about them is the inclusion of full wave bridge rectifiers. That means that no matter what way you plug them in, they will work.
Cable810
690
Would It matter on which of the
Operating Voltage Range
Unit: VDC
Current Draw @ 12 Volts
Unit: mA
Luminous Flux
Unit: lumens
Dominant Wavelength / CCT*
UNIT: nm / K
I get?
ItsOnVoy
2,401
I bought my 3157 bulbs and all my LED's from this seller on eBay and he is the best to me! I have never had a single problem with them or the seller and I have with other sellers. Here is a link
3156 3157 items in 3157 store on eBay!
Yes they are a bit higher in the price but cheaper then other sites and he's a great seller! I got the 13 SMD's and if you need a picture let me know.
Cable810
690
If ya Don't mind :smile: These them 3157 13 SMD http://stores.ebay.com/jaydencar08/_i.html?_nkw=3157+13+smd&_sid=996874044
ItsOnVoy
2,401
Cable810 said:
If ya Don't mind :smile: These them 3157 13 SMD 3156 3157 items in 3157 13 smd store on eBay!
Yupp those are the bulbs, here are some pictures of them
I like the SMD's much more then the regular LED's for some reason! Plus they are a bit brighter
Hope this helps with an idea of them :thumbsup:
Cable810
690
Whats the Diff between the 13 5050 SMD and just 13 SMD? I know Noob question :eek:
DJones
701
You've got data:
[PDF]http://www.wayjun.com/Datasheet/Led/5050%20SMD%20LED.pdf[/PDF]
Cable810
690
I guess I'll stick with the 13 Smd then.
Thank You al for your help!
ItsOnVoy
2,401
DJones said:
I don't think I have seen any car bulbs without SMT LED's.
Well you have your SMD LED's and then your regular LED's
I am saying this
[EBAY]200515806291[/EBAY]
vs
[EBAY]330677151059[/EBAY]
I like the SMDs more
DJones
701
When I was looking to buy my lights, I skipped all of the asian junk a best as I could. I must have missed those.
Cable810
690
What are the Turn Signal Bulb size? According to Lamp Replacement Guide Home they sould be 3757A. Does that bulb size apply to the Parking Lights? Or are they a differrent size?
14,950
Did you even look at that on the link you provided? They are the same bulb. the side markers are different
Cable810
690
ROFL Didn't even see the Parking lights LOL. The Front Side Markers are 194. I thought that was interior.
4,023
One in the same.
Rubberman
117
Are those plug n play bulbs, no other modification?
kardain
557
Posting from my phone, so pardon the random shorthand.
For the front park/turn, the socket will either be a standard or ck style. From what I gather, ck in the front is rare.
For the tail light: brake is ck, turn and reverse are standard.
The difference between ck and standard is the position of power and ground pins. Putting a standard bulb in a ck socket can result in bad things (from as simple as a popped fuse up to complex like a fire).... Ask me how I know :smile:
The video in this post will assist you in determining what style socket you have so you don't order the incorrect bulbs: http://gmtnation.com/showthread.php?p=18908
The bulbs you get are more than likely going to be polarity specific. If they don't light up, remove the bulb, rotate 180* and reinstall.
The only bulb that won't be a direct plug and play is the front turn/park bulb. The stock bulb is a 3757 and the led bulbs are 3157's usually. If you look at the above post, there are two nubs (or whatever the actual term is) that may have to be removed from the 3157 prior to install, afterwards it is plug and play.
Lastly, if you change your turn signals to LED, you must add a load resistor in parallel with the turn circuit to prevent what's known as hyperflash (bulb out warning). A pair of 3ohm 50w is needed if changing front and rear to led, a pair of 6ohm 50w if doing either front or rear.
Hth.
DJones
701
Old-fashioned china cheapies :yes:
My LED 3157 fit right into the 3757 socket. Load resistors, also old-fashioned.
kardain
557
I would have suggested a flasher replacement, but with the OP mentioning the price of the bulbs as a concern, I doubt a $70 flasher would be on the list :smile:
DJones
701
I think mine was somewhere around $10, but required additional wiring to accomodate both sides and hazards.
Firebaugh86
