Key stuck in ignition multiple transmission codes
tbl02
2
wisconsin
I have an 02 tb. This afternoon when I got home for lunch my key would not turn past the acc position I used the button to get it out. Figuring that the ign switch was the problem I replaced it. Now the key still sticks in the acc position and I have 3 trans codes p0740, p0785, p1860. My guess is the trans is not bad and that this is an electrical problem but not sure where to go. I do have power on both sides of fuse 47. Any help??
tbl02
2
wisconsin
Thanks for your reply. It gave a lot of good ideas but, in my case it wound up being a broken wire in the steering column.
jonnnnyj
