is it possible to put a TBSS cluster in an Envoy
Me007gold
1,106
Indeed it is possible, mileage will not match, but that can be corrected
SS cluster(with LED lights and blue needles) in my Trailblazer
Me007gold
1,106
ConeKilrAutoX said:
that is awesome. If my envoy didnt have DIC will it still work?
Indeed it will, jetttstream has a how to, on how to set up a box to control the DIC, or you could add a steering wheel with buttons and clock spring, do a small amount of wiring and it will just like it came from the factory.
ConeKilrAutoX
1,179
oh wow....thank you!
Short Bus
1,906
ConeKilrAutoX said:
can you put a 2004 tb SS gauge cluster into a 2004 envoy?
i doubted it was possible...has anyone tried this or seen it done?
Good luck finding one..........Can anyone guess why?.............
06 was the first year for the SS
Short Bus
1,906
ConeKilrAutoX said:
So it is not possible to put an SS dic into an 04 envoy then
IDK for sure, but IIRC the clusters changed in 06 and you need the same year (or close IDK, I'm don't know the cutoff years) that your truck came with. I'm sure someone here will be more help though.
ConeKilrAutoX
1,179
ok thank you! i was just curious I thought that could be pretty cool
Me007gold
1,106
Year does not matter, Ive had a 04 Rainier Cluster in my truck, before I put the SS cluster in and everything worked correctly. The only issue you may have is "program cluster' but it will no effect the way the cluster works.
Short Bus
1,906
What's this?
ConeKilrAutoX
1,179
nice....was there any extra wiring needed? or did you simply plug the new one in?
10,665
There's a write up in the articles section, may give you some good info
Edit: Nevermind, I thought this one had the info on tapping the wires under the dash for the steering wheel controls. You'll have to add some wires that go into the cluster harness. There's 4 wires (one for each DIC control button) If you don't go with a DIC steering wheel and make your own control box (this is the route I took) you just have to connect those 4 pins to ground, through a momentary button, and that's it.
ConeKilrAutoX
1,179
perfect. thats all i need. I dont plan on going with the steering wheel
last question. Will my new dic automatically receive mileage info from the car from before? thanks
Me007gold
1,106
ConeKilrAutoX said:
how would I go about doing the mileage correction?
You have to find some one who can fix it. You need to find an Odometer shop, Companys like USspeedo and Florida Speedometer can also do it, but they are a bit more expensive, or you can find some one in your area, who wil do it for much less. I got lucky, I found a guy on craigslist who did mine for $75.00.
ConeKilrAutoX
1,179
ah... ok thanks!
10,665
To get some pre-wired pins that you'll need to add to your cluster harness, you can buy a radio harness for our trucks off Ebay (the radio and cluster plugs are the same). Then just extend the wires to wherever you plan to mount your control box. :twocents:
[EBAY]390296663893[/EBAY]
ConeKilrAutoX
1,179
alright thanks for the help!
DJones
701
St. Petersburg, Florida
What you could do instead of reprogramming the cluster is swapping the internals. The outside would have the look you want with the inside known to the truck. :twocents:
ConeKilrAutoX
1,179
like this cluster gauge face? View attachment 18635
Blacktrails
34
Just to avoid any more confusion, all GMT360 clusters are interchangeable. DIC or Non-DIC does not matter. If you add a DIC cluster to a Non-DIC truck, the Gauges will function as normal but the DIC feature will only provide limited features, such as "Drivers door ajar", "low fuel", ect, and you cannot change between them due to the lack of buttons. There are some options for adding buttons as were mentioned earlier in this post.
Also remember that the BCM DOES NOT store the mileage the CLUSTER does. So if you have 80,000 miles on your CURRENT cluster and you buy one from, say, eBay that has 150,000 miles, when you install the new cluster it will read 150,000 miles. You have to take it to a dealership or maybe some mechanics to have it reprogrammed.
I currently have a 03 Non-DIC Envoy with a 04 Rainer cluster with DIC (that i picked up on eBay for 30 bucks shipped :yes:) but no buttons to control them............yet :biggrin:
DJones
701
CavScout1836 said:
Just to avoid any more confusion, all GMT360 clusters are interchangeable. You have to take it to a dealership ... to have it reprogrammed.
That's what my dealer said too, but I haven't tried it yet. However, they won't do the programming.
I currently have a 03 Non-DIC Envoy with a 04 Rainer cluster with DIC (that i picked up on eBay for 30 bucks shipped) but no buttons to control them.
That's a good price. I don't think I'll be that lucky.
Me007gold
1,106
Keep an eye on tbssowners.com I got mine there for about $100
TB360
169
There is actually one on sale right now for $160 on tbssowners. I got mine for $90 last year.
10,665
May wanna check in on this auction in a few days and see how high the bids have gotten.
[EBAY]140699817884[/EBAY]
