Hey all.
I've been getting a CEL that from what I can tell, typically occurs on the first day of weather where temperatures break into the 40's or higher. I haven't been able to get the code read yet because the CEL tends to disappear in 2 or 3 start cycles or when the temperatures drop back into the 30s or below. Being in the northeast it's been plenty cold with only a few warmer days this winter. I've been making sure I wait for the ridiculous secondary air injector to run its cycle on each start and have been ensuring the gas cap is on tight after each fill. Beyond that I am grasping at straws. Would a Cat issue show itself with warmer weather? Or O2 sensor issues? The only correlation I can account for is the weather. I suppose it could be a gas cap issue as I do refill towards the end of every week but I always make sure it's tight.
Other info: Truck is not lacking for power, there are no misfires and I am not seeing any issues with gas mileage on my daily 45 mile RT commute. I did clean and re-oil my air filter towards the end of last year. Also had the fuel gauge sensor replaced through the non-recall. First time this issue happened was last Christmas with a temp drop from 60, 50, 40 the days prior to low 20s on the 25th and back into the 40s immediately following. The CEL hung around, so I disconnected the battery and reset the CEL. All other instances it has self-cleared after a few cold starts. The latest incident, it appeared this past Saturday (started car in low 40s, drove later in low 50s) and carried through Sunday (ran car twice when it was in the 50s), stayed on through yesterday morning (low 40s drive to work), was on during lunch drive to run errands (mid 30s) and was off on my drive home (still mid 30s). Remains off today with temps in the 20s.
4.2L '07 with 86k.
Anyone have any ideas? Hoping I can get a few days of warmer weather to see if it sticks around.
TIA.
4.2L '07 with 86k.
TIA.
