EHJIII
2003 Suburban with 230k miles. Had to pull the instrument cluster. After putting it back and turning the key to position 2, the only warning lights that would light are check engine and the brake light (parking brake engaged). The normal light diagnostics prior to starting no longer occurs. Start engine and then all lights temporarily do diagnostics then go out (except brake since parking brake engaged). Oil pressure then pegs high. Reseated the connector. No change.
Saw something on line for resetting the cluster using the key, turning the head lamps on and off while pressing the reset knob on the upper right of the cluster. This did make the light diagnostics work one time when the key was placed in position 2 but the oil pressure continued to be pegged high. Putting the key back to position 2 a second time after the reset did not resolve the light issue.
I loaned my quality code reader and only had a blue driver code reader which did not access hardly any information so I can’t provide detailed code or system performance until tomorrow.
any ideas or have I finally suffered the curse of the instrument panel failure?
