If you could, provide detailed pics, and details, its one of my upcoming projects for my GMT
Sorry no pics, but will tell you what I did with detail
The hardest part of the whole install were dealing with the hog rings, and deciding where to tap power. The seat is a little heavy/awkward to remove.
Installing the heating pad:
To make the job easier on the bottom cushion I decided to lift the fabric up as much as possible. This required detaching the fabric from the cushion at 4 points. The points are held in place with hog rings. The hog ring pliers that come with the dorman kit are totally useless. I ended up bending the rings that were on there, then reusing them (with needle nose pliers) when putting the seat back together.
The seat back was much easier to work with. I was able to just slide the fabric up and insert the heating element.
For the wiring:
I purchased a dorman 4 post relay. *I tapped main power at the mega fuse, the only other place I could think of to get direct power would be right off the alternator.?. (if you have a better place to tap this power please let me know!)
On the relay (legs 85, 86, 87, 30), I connected:
Main power (with 10amp inline fuse) to leg 30
Grounded leg 85
Used a fuse tap on front fuse box IGN E fuse location on leg 86
The heater kit connected to leg 87
I installed the on/off button on the side of the seat. I drilled a hole in the plastic trim piece where the forward/back/lumbar buttons are. I put it in the top right corner area. There is a spot that will let it slide right in perfectly.
It is working good, and the seat warmers are really nice, and on high setting are very warm.
My concerns:
Where I tapped the main power, is there a better place?
The fuse tap, I know there is a certain way the fuse tap should be inserted so that power is on the correct leg. I have not put a volt meter on it to determine which leg that is. Right now I have the pigtail part of the tap going towards the driver side fender. Do you happen to know the correct leg?
If anyone sees a problem with this install, or has a better way, PLEASE let me know
