#1 Still chasing parasitic battery draw. There is no IPC installed at this time. (sent it off for rebuild)
#2 Midgate is pulling 480ma. If I remove fuse #27 (15A midgate) battery draw drops to .005 after a few minutes.
#3 When I connect the battery, the midgate latches partially unlock. The gate will move a bit but not fold down. I can push on it and it relocks.
#4 If I actually roll the mid window down and push the button, it doesn't do anything.
#5 If I unplug the "window is down" switch the draws stop and the latches lock. I plug it back in and the latches go back to a holding partially unlocked.
#5 Now it gets weird. I checked the switch and it is normally open. When I push on it it closes. Apparently working as intended.
#6 I short the connector that goes to that switch and nothing happens.
#7 So connecting a plug to an open switch is activating the latches and shorting the same plug has no effect. /dogheadtilt
Could the missing IPC/DIC be causing this?
