identifying differential?
sunliner
365
I have a GU6 RPO code which tells me what the axle ratio is. I'm not up on this stuff...does that also indicate what differential I have? about to change the fluid out and want to make sure I get the right kind.
Only thing you would need to know is if it's a limited slip diff or not. The only ones that got those are the AWD trucks such as the Bravada, Rainier and 9-7x. All the others, 4x4 or 2wd, got either the open diff or G80 locker. Both of these do not need an additive. The limited slip does.
sunliner
365
thanks much!
bobby2175
