I don't have Bose after all
fadyasha
1,134
Well went to install a HU today and from what the guy tells me I don't have Bose! So my gmos-04 is worthless! Is it possible I screwed up on this? The answer is yes but how do I make sure ?
Black_tb
817
couple ways one being you would speakers/ tweeters in the dash I'm sure there is a code in the glove box but off hand don't know what that would be and last there should be a amp some where
STLtrailbSS
Amp behind rear panel passenger side. Cant you just cut the RCA's and treat the wires as a non bose harness atleast Scoche Harnesses are like that
fadyasha
1,134
Thanks guys! I could try that but first hand when tried connecting the rca's nothing in the back. My rear controls were out.
Yup no Bose what a bummer lol! I don't even know how I was so sure I had it lol
STLtrailbSS
anything in the manual about adapting the harness for non bose? Or its it strictly bose don't have experience with GMOS
fadyasha
1,134
Strictly Bose! There's the gmos-01 for mine. I'm sure there's a way around it but my Ltz has so many options and I'm sure I'll screw something up.
I contacted the seller and they said I can send it back and they'll exchange it for me with what I need and refund the difference :wink:!
Unless a fellow member wants it I could sell it instead lol
MAY03LT
Delmarva
fadyasha said:
I have the TB LTZ model which makes it a bit more difficult to find a unit because of the:
1. Steering Controls
2. OEM Bose System
Well you probably already know this, but yeah, you can't blame us for this!:cool:
This is a good example of why the trim level can't be used for determining what options that you have. FWIW, my 03 LT didn't have bose or onstar, but it did have the LTZ wheels.:crazy:
DJones
701
St. Petersburg, Florida
MAY03LT said:
...my 03 LT didn't have bose or onstar, but it did have the LTZ wheels.:crazy:
Bose and OnStar were optional on most trim levels, and the "LTZ" wheels only came on the SWB LTZ, TNF, EXT, and EXT TNF. AKA Ascender wheels. Maybe the dealer put them on.
fadyasha
1,134
Loool seriously man! U live and learn
MMIN
55
When you turn the OEM radio on it will say BOSE on the display for a second. Also you can look through the grills in on top of the dash to see if there are speakers there. Last in the glovebox look at the RPO code list - UQA should be premium audio. If you tried to use a bose interface in a nonbose vehicle you would normally get very low volume out of all of the speakers. Are you saying the front speakers seemed ok with the harness?
DJones
701
:confused: Mine doesn't. :confused:
However, it does have a white decal that is on there 24/7/366.
MMIN
55
Good point forgot that one! If it doesn't say Bose when turning on it is right on the face of the radio - bottom left of the display I believe?
STLtrailbSS
Fad this only mean ones thing. Time to make your own bose system order amps ASAP! SonicElectronix.com :rotfl:
Boricua SS
3,080
this is false for determining if you have BOSE...
my facrotry HU flashed BOSE when i bought my SS... however, no amp in the rear cargo area, no UQA RPO code, and no tweeters in the dash vents...
MMIN
55
Did you buy it new or used? It isn't uncommon for customers to want a 6-disc instead of the single disc and dealers will swap a bose radio into a non-bose vehicle. Program it up and you have a vehicle like yours that appears to have Bose but really doesn't. If you bought it new and know this isn't the case, than that's strange and I'm not sure how that could happen.
Boricua SS
3,080
i bought it slightly used.. only had 9400 miles on her... less then a year old.. so if thats the case.. someone swapped things out fast... i didnt have the 6 disc.. just a single POS! :rotfl:, so why someone would want to swap to that is beyond me...
MMIN
55
i bought it slightly used.. only had 9400 miles on her... less then a year old.. so if thats the case.. someone swapped things out fast... i didnt have the 6 disc.. just a single POS! , so why someone would want to swap to that is beyond me... .
In that case chances are your truck got the raw end of the swap and you had the 6-disc. Guess you don't have the window sticker for it?
Fascinating. In my long time with this platform, I never heard or saw that. And it seems it's not definitive. :confused: I have an SLT with Bose and mine doesn't flash on the display. What POSSIBLE reason would GM/Delphi have to flash a LIE on the display? :mad:
Boricua SS
3,080
if it did have it, then im unaware... and yes i have the sticker for it... sticker just says AM/FM Stereo, then CD Player underneath it...
oh well no biggie for me... i have since gone waaaaay aftermarket :crackup:
STLtrailbSS
It's much easier to rip it all out then to find out if you have bose. I have gone through with that method in every vehicle I have had lol
4,023
I have an LTZ with the 6 disc BOSE system (RQA RPO, speakers, amp) and mine doesn't do anything like that either.
MMIN
55
The older radios should have Bose printed on the display, the newer ones and nav units should say it on the screen when they turn on.
Interesting.. I guess there is always the possibility that if they ran out of radios they would put in whatever during assembly, but being even slightly used I would guess something else happened. Anything from a dealer swap like mentioned earlier, or the truck was traded in with aftermarket equipment and the dealer put it back to an OEM radio, or the face was damaged and replaced with one that said Bose, etc.
Boricua SS
3,080
that could be... but either way, the radio has since been long gone :crackup:.. no less then 6 months did i have all my aftermarket stuff in.. and havent looked back since..
Firebaugh86
