Have an '06 Trailblazer LT w/auto climate contols. Had an issue with it not switching to vents at all, would only stay on floor/defrost. I replaced one of the actuators yesterday, there are 2 under the driver's side dash. Now when you turn the vehicle on it will blow out of the top vents finally, but after a couple minutes it will switch to the floor only by itself. It's not in auto, it's in the top vents only mode. If I switch to floor defrost that works and when I go back to top vents only it's just the floor again. Is that other actuator bad? Or the main control unit in the dash? Everytime you shut the car off and then back on, it will do the same thing over and over. Disconnected battery, pulled the fuses under the rear seat (that does nothing at all, the air still works and the display is on, not sure what those fuses are for if they don't do anything) tried the calibration multiple times to no avail. This happened overnight, no dead battery or change to the vehicle. Any ideas? I'm thinking the main unit is malfunctioning? Appreciate any ideas/help. Thanks
