So, I think I may have a solution to the temp actuator problem that seems to be common with these vehicles. Mine started to stick in March and would not go fully to hot or cold. It would not go pass the halfway point. I noticed that if I grabbed the actuator through the glove box and pulled on it slightly the actuator would work again and finish the cycle. It seems that it is binding somewhere at the halfway mark. I didn't pull hard, just enough to pull it slightly from the shaft.
I was thinking maybe the actuator was mounted to tightly to the shaft and is causing binding issues. Maybe using washers or shims might relieve the excess pressure on the shaft while still being able to securely mount the actuator? If this works I would be relieved/annoyed because it would fix a lot of other owners issues, but almost seems like a setup from GM to insure labor from the constant problems this causes.
Ideas on this?
Ideas on this?
