How to do a fuel pressure leak down test on a 2004 4.2 i6?
Sqrly
269
Livingston CA
I know how to check the fuel pressure but I also want to check for leak down. I'm looking for leaky injectors.
On my 2004 the schrader valve is at the fuel filter and before the pressure regulator.
Q: Can the regulator affect the pressure leak down test?
TJBaker57
3,328
Colorado
Sure can!
So the issue with testing for leakdown becomes:
Is it leaking back into the tank??
Or leaking from one or more injectors??
Is a 2004 a single pipe system or two pipe?
Can't remember. Will have to research that.
TJBaker57
3,328
Colorado
Thinking yours has the regulator in the engine bay,,,, since I seem to remember you mentioning checking the vent line for fuel smell.
Sqrly
269
Livingston CA
Sure can!
I can show you which system it is.
I'm going to assume I need to plug the return line off the regulator to see if the injectors leak down with something that would hold at least 80 psi, to be safe. I don't want to spray fuel across the garage.
Image Source: https://nemigaparts.com/cat_spares/epc/gmc/56s-t/
Sqrly
269
Livingston CA
Would you happen to know what this, I think it's a schrader valve, is for? It seems to be on the vapor recovery line.
Spanky73
