HID Relay question.
Filter
47
I have read that when our DRLs are on that the headlight is getting about 10v. Not good for a HID system.
Is it possible to have a relay that will close its contact at 10v and not the full 12v?
If this is possible then the HIDs will always be getting full power DRLs or not; because it will be drawing 12v+ directly from the battery.
Thoughts?
jham
1,334
Thoughts?
isn't that what having the relay doing? When I installed mine the relay was getting hooked right to the battery. The factory wiring was only hooked to it to throw the relay or am I wrong.
Me007gold
1,106
The purpose of the relay harness is to protect the headlight wiring. The HID's run higher voltage and can melt the thiner wire of the headlamps.
Thoughts?
As I understand it, the DRL's get 12v, but it is only powered 70% of the time.
Kind of like rapidly flipping a switch ON and OFF.
I have the harness, but the relay would buzz, because of the ON/OFF cycle of the DRL.
After the capacitor mod, the buzzing stopped.
06Envoy
An easy plug n play method to do the cap mod is to use 9006_DRL_MODULE . These plug in just before the relay harness.
It's a good solution for the EXT/EL guys who don't have redy access to thier BCM to DIY....
Canadian Mike
738
Would this solve the buzzing of the ballast or just the buzzing of the relay? I've got a relay harness only for my lows and both ballasts have a low buzz.
ItsOnVoy
2,401
The cap mod will solve the buzzing over all, it will run the drls at 12v 100% of the time so the relay and ballast will be fine, just the life of the bulbs will be shorted due it running more often is all.
Canadian Mike
738
Thanks, I already know about the cap mod. :smile: Just looking for an alternative method and was wondering if the v-leds actually worked.
ItsOnVoy
2,401
Oh okay got it!! yeah I am curious if it works also because that would be a good idea for me since I do not want to mess with any wiring in the car
MAY03LT
Delmarva
They work. I installed one in an 07 and the headlamps had a full 12v signal in drl/perimeter lighting modes.
ItsOnVoy
2,401
Is that site trustable? I usually only buy from ebay and thats it lol
MAY03LT
Delmarva
I bought the LED reverse lights from them a long time ago, so I'd say absolutely.
I forgot to mention that if you have a relay harness, you only need one. If, for whatever reason, you don't have a relay harness, then you need one per side.
ItsOnVoy
2,401
Yes I have a relay harness hooked up, so if I get this right, this will make my DRL's run at 100% power so they do not harm the ballast or the relay right? Just the life of the bulb is shortened since they are running more often?
Really only one? So would I just hook it up to the driver side and the passenger would work also? How does that work?
MAY03LT
Delmarva
This will give the relay input 100% power and the relay/ballasts won't buzz in drl/perimeter modes.
Yeah since the low beams will be on pretty much all the time.
Your relay harness should have one 9006 input that plugs into the drivers side low beam connector. The drivers side low beam connector is what will have the 80% PWM duty cycle in drl/perimeter lighting modes. What that module will do is "modify" that PWM signal into a full 12v signal BEFORE it gets to the relay.
It would be inline like this:
Drivers low beam 9006 connector ===== VLED MODULE ===== relay harness 9006 input
ItsOnVoy
2,401
Which will save the life of the relay/ballast so they can be reused right? Because I know that the 70% power kills the relay and ballast after sometime and they have to be replaced...or am I wrong on that?
Thats perfect thank you for the help! :smile: I will be making that purchase quite soon to fix that problem! :thumbsup:
MAY03LT
Delmarva
Yeah man long term it will shorten the life. Short term would be the relay chatter/ ballast buzz along with the one or both lights flickering or not working in drl/perimeter modes.
Cool, let us know the results!
ItsOnVoy
2,401
So I connect it right between these right? That is from my relay to the factory harness
Darkrider_LS
9,332
Hate to dig this up however I have a question about the cap mod. Ok as I understand things the capacitor or vled module would go on the positive wire between the factory harness and the relay harness for the HIDs correct? Anyone know of of a module similar to the vled unit since it seems to be discontinued or what size of capacitor is needed if it were to be integrated into a custom relay harness?
DDonnie
2,631
If you are willing to tap into the bcm harness, the mod is ridiculously easy (as long as you don't have an ext). I literally did it in about 5 minutes using this capacitor from radio shack, some spare wire, and a couple of wire taps. 10µf 50V Axial-Lead Electrolytic Capacitor | RadioShack.com
Here's a thread on the OS with exact instructions and good pictures.
http://forums.trailvoy.com/showthread.php?t=64575
Darkrider_LS
9,332
DRL Capacitor Mod - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Hmmmm i was looking at this or doing a DRL killer...so either one works...I seen one method of doing the DRL killer that allows my auto headlights to work still. But as i understood this cap mod...take capacitor solder it between two pieces of wire, Tap the wire on the positive end of the capacitor into the BCM wire and the other end bolted directly to ground. Am i understanding this correctly? And this will allow everything to function as normal other then the fact that the DRLs are now 100% power/cycle rather then the pulsing it does from factory?
MAY03LT
Delmarva
Yes and yes.:yes:
DDonnie
2,631
That is exactly correct. It's crazy easy to do on a SWB (pain in the freaking arse on an extended)
Darkrider_LS
9,332
MAY03LT said:
Yes and yes.:yes:
Awesome! Ironically enough i watched your DRL killer vid on youtube last night. Im thinking i may try the cap mod first and eventually do the DRL killer the same way you did later on to have quad headlights on high beam. :thumbsup:
Awesome! Yea this is one of those times im glad i have a SWB.
javier perez
