These HID lights have been nothing but headaches since day one. I had issues a few months ago and after some lenghty trouble shooting, the issue was finally resolved. Thanks again to all that helped me out the last time.
New month and new problems. Shortly after i fixed the last problem, a new one popped up. After about 2-5 minutes of driving, the passenger HL would cut out. To get the light to come back on I had to turn the lights off then back on. That solved the problem for another 2-5 minutes, then the light cut out again. The driver side HL never had this issue. So i figured that the problem was the ballast and could have been a result from my first HID problem. So i called DDM tuning and they said to ship back the ballast and a new set would be on the way. I got the new ballasts in today. I mounted them, plugged in all the wires and double checked everything. I drove around and BAM!! the passenger side HL went out after 2-5 minutes. Same deal, turn light off then on and repeat.
Now I'm wondering if it was the ballast this whole time. I have the kit hooked up properly. The HID killer works fine and I even have the heavy duty wire harness added. When I drive with my high beams on, I DO NOT experience the passenger light turninng off, Its only with the HID's.
Any suggestions??
Thanks,
Kevin
Any suggestions??
Thanks,
Kevin
