- Dec 29, 2012
- 91
I'm begininning to get into that, "I wanna change things," groove on my car and my next is going to be HID's and LED's. I've searched around, so I have a basic idea of what I'm getting myself into, but I still have questions that I've been unable to find by searching.
I plan to put 35W 6000k HID's in for both the fogs and the headlights. I know that the headlights are 9006 bulbs and the fogs are H11 for the Rainier, but I have a few questions.
1. Do I need to use a relay, or will I be ok if I simply do the capacitor mod since my kit I plan to use is only 35W?
2. Where can I get a capacitor, and what size should I use? I want to keep my DRL's, so I don't want to use a killer.
3. Are the stock assemblies a good projector without scattering light? Can someone post a picture of their HID's without projectors so I can see how the cutoff appears?
Now onto the LED questions. I have stock tail assemblies, and I want a bright bulb so that I can put a tint over my tails and I'd still be able to have alot of light show through, as to not risk being pulled over. I also want to do the Rainier eyebrow LED's.
1. Will LED's show through a tint well enough for me to consider getting them?
2. What size are the tail light bulbs? I know the eyebrow LED's will be 194's, if I'm correct, but I'm not sure about the tails.
3. What bulbs will give me the best output and look?
4. Will I need resistors, or will I be ok just putting the bulb in, plug and play? If I do need them, what ones, and how do I do it?
5. Is it illegal to take out amber lights from the front of the car? If I do the eyebrows, I'd be removing the amber lights that are there from factory and replacing them with a white light.
Thank you for the help!
02olds
02olds
