Anyone compared the two? Any thoughts on the two? Heard rumors of 55W kits melting stock wiring on some vehicles.
DevilishT2003 said:Anyone compared the two? Any thoughts on the two? Heard rumors of 55W kits melting stock wiring on some vehicles.
Boricua SS said:i have seen 35W and 55W in person... 55 is waaaay brighter.. and (this happened to my friends 08 LT) melts the fog light housing since its so small... he does have 55W for his lows, but he has the relay harness, so all is ok.. hes had them a little over 8 months now.. no issues.. (our factory bulbs are 55W), but for HID sake.. 35W is plenty bright over our factory halogen... 55W just pisses off the other drivers![]()
it will annoy a ton of people and bring cops attention to you!! I would stick to 35w because they are plenty bright! Now keep in mind, if you do go with 55w (hope you dont lol) the color on them do get washed out a bit. So a 55w 8000k will have the same color as 35w 6000k and so on.Boricua SS said:55W just pisses off the other drivers![]()
:wootwoot:Bub said:I have 55w 6000k HID in both low beams and fog lights, my fog lights are stock housing however aftermarket wiring so I have no issues other than on my low beams, i have to turn them on first then start the truck, or if i use my remote start then I have to make sure the truck runs for a few minutes then i can turn them on. I would like to fix that if anyone has any suggestions, as I am going to fix my drl killer to allow auto-on headlights
Boricua SS said:^^^ great post!! anyway to get a side by side picture for the OP to see the difference?
ItsOnVoy said:Are you running your HID's to your factory harness or a relay harness?
Bub said:factory harness
hope this helps! ItsOnVoy said:That can be a reason to your problem! I would get a relay harness (there about $10-$15max) and run that with your HID's. That will draw power from your battery and leave the factory harness alone. The factory harness is too weak for the amount of power the HID's need and you are risking a headache if they melt on you etc. I have a starter also and at night the lights always turn on perfectly when I remote start it so I think a relay will help big time! I always recommend themhope this helps!
Bub said:Holy thread bump i know however i did add the relay harnesses and there is no change. any suggestions?
NinjuhhNutz said:when you say "have to turn them on then start the truck" what exactly happens if you don't?
my passenger side bulbs flickers with the R/S or when I crank it at night...not a biggie for me right now and I haven't gotten around to the cap mod![]()
Sparky said:55W should never ever have been rebased to fit any sort of halogen reflector.
35W HID is similar brightness to halogen 65W high beams. Stick those in a reflector and ehhh a little bright for oncoming traffic (especially depending on the housing some are REALLY bad). 55W? Yeah, nothing like shining 2x brighter balls of light into oncoming traffic to blind them![]()
Showtyme said:Ive been thinking about going with 55 watt lows but I think im going to completely black out my headlights which would dim them down to about 35 watters. Yes or no?
