Hi, Thinking about rear end swap, btw 04 TB w G80, & 08 TB non G80
SSdriver3
7
Hillsboro, OR
Thinking about a rear end swap, between a 04 TB with G80, and a 08 TB non G80, both gear ratio's are 3.42. is there any differences I need to be aware of? it looks like the calipers won't be a problem....., but drive line...... mounting points......... (I bet those are same)
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
04 into the 08 you will have all kinds of codes thrown.
It will bolt in but the 04 does not have the right ABS/Stabilitrak stuff for the 08.
If you put 08 under the 04 it is no issue, just leave sensors to plug the holes
8,047
What they said. If you are swapping from the 08 into a 04, your fine, but not the other direction..
You never indicated what truck you have, so all we can do is make assumptions.
MissCrutcher
