I just finished replacing the fuel pump with a low cost assembly from Ebay - yeah I know I should use AC Delco blah blah blah...... It has a lifetime warranty I hope I'll never use.
When I disassembled the old assembly to extract the pump, I made an interesting discovery. It appears that the TB fuel pump assembly has a standard pump inside - used by a multitude of other vehicles (kia accura ford gm etc.)
Check out this ebay listing:
https://www.ebay.com/itm/NEW-ELECTR...ash=item25ab9ae1c5:g:fw0AAOSwB-1Yp5sh&vxp=mtr
Scroll down a bit to see the exploded diagram of the pump itself. Sooner or later the brushes will wear out and the pump performance will decline or fail intermittently. Guaranteed to happen to any similarly designed pump - whether or not it is the OEM Bosch or one of the copies.
You can always afford to replace an $8 pump - if you are hitting 200k miles then you should just replace the pump as preventative maintenance.
It's not difficult to take apart the case and extract the pump.
Funny how it works - take it to the dealer and pay $1200 or Ebay for $8 and a couple of days work. Choose your poison
