- Jan 3, 2015
- 83
2008 Trailblazer 4.2, 120k, rust belt, working under jack stands.
I have a minor fluid leak coming from the transfer case front output shaft seal. To replace, I need to pull the front driveshaft. I have the four bolts removed from the u-joint, but I can't get the driveshaft to pop off. I think rust has a good grip on it. Removing it looks doesn't look hard in the two youtube videos I found.
I sprayed it a few times with PB Blaster, been working on it with a pry bar and 4lbs sledge. It isn't popping off. Any suggestions?
As shown at 2m20sec here:
As shown at 6m00sec here:
EDIT: FINALLY GOT IT
