Front Axle Seal, how to replace?
Integraoligist
14
Having both my front HUBs changed under warranty at the dealer right now... and there was a small amount of oil leaking from the axle area so I had them check it out... they just called and said I need the SEAL on the front axle replaced, to the tune of $300 (not covered under warranty because it's "wear and tear"
Am I able replace this myself? And about how much is the seal?
Thanks all!
George
57
if your mech inclined you can do it, get a seal install tool dont want to blow a seal :biggrin:
seals are cheap about $15
Wyle
Thanks all!
I did the driver's side seal of the differential a couple weeks ago. Seal is $15-17 at the dealer (only). Lots of previous reports of parts places offering a seal that doesn't fit. Part number is 19257296 (which replaced 12471618). Took me a little over 3 hours to do, but Tucson is a rust-free environment. Bought a $10 seal puller at Autozone which helped a lot. Also rented a seal install kit, which was basically a set of aluminum disks with a screw-on handle that you can beat on. You also need a 35mm (stock) or 36mm (aftermarket) socket to remove the axle nut. Also "rentable" at parts stores.
Regulator has a CV removal how-to :thumbsup: in the article section for the passenger side. Pretty much the same for the driver side. I did use allen wrenches to check the spacing between the CV tripot and the differential housing before I pulled it. Wanted to make sure I got it back in all the way. Mine was about 8mm.
DJones
701
St. Petersburg, Florida
I replaced mine too. It took a few hours, mostly because I accidentally got the pinion seal. Completely different seals. I used no special tools other than a hammer, screwdriver, and 2x4.
Integraoligist
14
Anyone know of a good how-to or step by step process?
I'm not 100% on the terminology so pic's is what I go by.
I have to pickup the Envoy tomorrow from getting the hubs replaced, I'll get that seal from them as well... as long as it's $12-15, otherwise off to the next stealer.
Wyle
and it comes with pics
AbsoluteZero
211
Thanks all!
You must have an aftermarket warranty. My front axle pinion shaft seal was replaced and I had GMPP. There was a recent thread where several comments suggested front axle seals were covered under warranty.
Integraoligist
14
Yeah, I bought the truck about 6 months ago at 109k miles on it and got a 2-year or 24k mile "CarOne" warranty, now it has 124k miles and apparently the seal is a "wear and tear" item so it's not covered which is total BS
Firebaugh86
