Fog Light Switch
EnvoyXL_2006
6
Hi,
Is there any way to give the fog lights memory so that if they are on when you turn the truck off they will come back on the next time you start the truck and vice-verse? Thanks!
suburbs
86
If you follow the link below, shows a way to set up so your fogs will be on whenever your daytime running lights/headlights are on using some diodes for around $2. When you turn on high beams, highs + lows + fogs all illuminate, but you lose the ability to manually control fog lights.
http://gmtnation.com/f33/cheap-quads-fogs-211/
jonu
