2002 TB, passed down to me from good friends, 198k miles and has always been extremely dependable to the original owners. Seems to be in great overall shape outside of these gremlins/issues I'm having. I've cleaned out the TB so far with it off of the truck, reset ECM for 30 mins. Also replaced ign. switch and the exhaust camshaft solenoid that requires moving the power steering pump to the side.
First off I had no issues for almost a month until I had to drive long distances and things would be intermittent after about an hour of driving. I'd be cruising at 65mph and the RPMs would surge around the 3k mark, then the ABS light would come on without a check engine light coming on. After about a week or 2 of the hour+ long trips, the truck started stalling on me while on the highway. It allowed me to restart it at first but the following week it was worse. Not cool since I'm bringing my pregnant wife and child to a specialist, which is the reason for the long rides.
1st breakdown in the middle of nowhere. The RPMs would surge, the ABS light would come on and the truck would stall. Every mile or 2 it just kept happening and limped to a gas station. I did the few changes I mentioned above, had a check engine light for the exhaust solenoid so this was included in my things to do. Truck restarted but my tow truck driver said he had a TB with similar issues and it was a gremlin in the ignition near the key.
Had a mobile mechanic come out to trace the ignition issue and he found a bad ignition wire that was broken. He drove all around town with his reader hooked up and it seemed to be running great. 2 weeks later I'm on a 1 hr drive and the truck doesn't stall on me but the RPMs start surging again, ABS light back on and I have the whole family with me! Arggg
Who has had a similar issue and knows what the problem is? I wish I was good with a multimeter but I'm not, can't really afford to spend much more either. Please help me...
Edit- My mechanic said the wire was broken due to the harness just being very tight around where it looms through and not being long enough.
