- Aug 25, 2012
- 955
I think my truck loves to have random issues. So it is very minor and I myself couldn't care about the idiot light at all but don't know if it can cause me to fail an inspection or not. My dash's fasten seat belt light isn't flashing at all or even lighting when I first start the truck or when I take my belt off while driving. I first noticed this about 2 days ago. In the past I had weird issues where I would get in, start my truck without my belt on and the light wouldn't be on, then I would put my belt in the buckle and still no light. Sometimes when this happened, if I were to push myself off the seat and then back on the seat the light would flash to warn me to buckle my belt but now it isn't doing that. I don't know if it is the sensor in the buckle that may be bad or what the deal is.
I have tried to unplug the 2 wire harness under my seat and turn the truck to run and the light wouldn't light up whether I was in the seat or not. I tried to wiggle the belt buckle around while the key was in the run position and still no light. I tried to remove and reinstall my belt from the buckle without any light. I tried moving around in the seat without the light coming on. Now here is the funny part, I know the light isn't burnt in the dash because if I play with the key in the ignition I will get all the gauges to start going up in the dash and once in a while the fasten seat belt light would come on for a second and then go out.
Is there anything else I should check for this? Do you think it would fail inspection at all without that idiot light working? Any tips would be appreciated. Again I really don't care about the light, I wear my belt and force my passengers to wear theirs at all times too but don't want to fail an NYS inspection when it comes up this august.
